Motor Rocks
I was driving withouot my hood on.. and a notices that my motor kinda tilts back a little when i get on it hard.. it doesnt move if you move it by hand. and it doesnt move if you driving normal.. its only when i get on i hard... I just swapped the motor and put in window weld in the mounts and let it dry for two weeks so i know that the mounts are solid... Isnt it noraml for it to tilt when your driving hard?
I am not saying that your torque mounts are ripped, but it is a possibility. I have added energy suspension bushings into my oem mounts. There are two mounts underneath the front of the car next to the wheel where the frame is. There is also a pita one up on the firewall. You can either replace your mounts/fill them with silicon(I wouldn't do this to my own car)/add energy suspension bushings/change mounts with poly mounts like http://www.jimfab.com sells. The mounts will rip with the force some of us hard driving ppl put on our cars. This will give the engine some more room to flex which will lose a little power.
