t-belt question
Old May 15, 2005 | 09:43 AM
LSVtechnologytur...'s Avatar
Default t-belt question
Hey guys, sorry for the bad pic, but in the red area there is a little gap between the belt and gear. is this safe? I cannot tighten the tensioner anymore
Old May 15, 2005 | 09:52 AM
biotech0123's Avatar
Default Re: t-belt question (vtec'n)
If you don't feel safe with it loosen the tens bolt and turn the engine a couple times and the tighten the bolt back up and you should be fine.
Old May 15, 2005 | 11:54 AM
Default Re: t-belt question (biotech0123)
do you guys ever have any slack there?
When i start turning the motor by hand it gets a little space there right before it spins, then goes away after its moving.
Old May 16, 2005 | 03:30 PM
anyone have a picture of the amount of normal slack when rotating the motor?
Old May 27, 2005 | 07:12 PM
Its fine I noticed it on my b16 also right before the intake cam gear
93ej1coupe
Sep 30, 2007 03:14 PM
not so civic
Honda S2000
13
Oct 26, 2004 11:11 PM
mattssi
Mar 12, 2004 08:33 AM
Drag-On23
Mar 26, 2003 05:03 AM
tilt
Nov 19, 2002 06:15 PM
