how to use a timing gun on h22a
Old May 15, 2005 | 09:39 AM
DarkBB4's Avatar
Default how to use a timing gun on h22a
I don't see any hash marks on the crank pulley...how can i time my car? I've heard people say to do it by the flywheel, but i have no idea how to do that. Any help would be greatly apreciated. BTW i searched, but none of the searches i came across were about a h22a
Old May 15, 2005 | 09:44 AM
prelittlelude's Avatar
Default Re: how to use a timing gun on h22a (DarkBB4)
there is a timing window on the tranny housing, you pull the little ruber plug and you use the timing gun on cylinder number 1 the one closets to the power steering pump
the are 4 marks on the flywheel, a TDC mark and a 15 * mark that has two smaller boundry markers slightly smaller before and after the 15* mark, the idea is to get the timing gun to flash and have the pointer on the engine block doint at the 15* mark at idle when the car is warmed up,
you kinda hae to dig in and figure it out
Old May 15, 2005 | 10:08 AM
92hondalude's Avatar
Default Re: how to use a timing gun on h22a (prelittlelude)
i hope my after market act prolite flywheel has all the marks on it
Old May 15, 2005 | 11:05 AM
DarkBB4's Avatar
so where do i point the timing gun?? I thought i just point it at the little flywheel window, and turn the distributor till it lines up? what about cylinder number one???
Old May 15, 2005 | 02:14 PM
Atheist's Avatar
Default Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">so where do i point the timing gun?? I thought i just point it at the little flywheel window, and turn the distributor till it lines up? what about cylinder number one???</TD></TR></TABLE>
You hook the part of it that goes over a plug wire to that which is going to cyl1 nerd. Thats all he meant!
Old May 15, 2005 | 02:20 PM
bb_one's Avatar
Default Re: how to use a timing gun on h22a (92hondalude)
I believe it does, my ACT Streetlite flywheel has all the marks on there.
Old May 15, 2005 | 03:13 PM
h22 civic's Avatar
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">
You hook the part of it that goes over a plug wire to that which is going to cyl1 nerd. Thats all he meant! </TD></TR></TABLE>
lol @ nerd
Old May 15, 2005 | 07:21 PM
951dc5's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">the are 4 marks on the flywheel, a TDC mark and a 15 * mark that has two smaller boundry markers slightly smaller before and after the 15* mark, the idea is to get the timing gun to flash and have the pointer on the engine block doint at the 15* mark at idle when the car is warmed up,</TD></TR></TABLE>
i'm kinda confuse there... a DTC mark and a 15*, when i did my timing adjustment..all i see is that mark that looks like a cross +. That's wat i line up with the pointer, so am i doing it right? or i did something wrong?
Old May 15, 2005 | 10:41 PM
Sabbotage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">i hope my after market act prolite flywheel has all the marks on it
yep it does..... i have the same flywheel
Old May 16, 2005 | 05:17 AM
Default Re: (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">
i'm kinda confuse there... a DTC mark and a 15*</TD></TR></TABLE>
your confused because its TDC not DTC
jk
Old May 16, 2005 | 06:13 AM
stupidfox's Avatar
Default Re: (92hondalude)
so there will be one mark, then 3 marks kinda closer together? and youre shooting for the middle one of the 3?
so is it the same for H23?
Old May 16, 2005 | 10:15 AM
Default Re: (thestonerhimself)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thestonerhimself &raquo;</TD></TR><TR><TD CLASS="quote">so there will be one mark, then 3 marks kinda closer together? and youre shooting for the middle one of the 3?
so is it the same for H23?</TD></TR></TABLE>
yes
Old May 16, 2005 | 10:23 AM
syntax.'s Avatar
anyone know if fidanza flywheels have the timing marks? i forgot to look when i was installing mine
Old May 16, 2005 | 12:40 PM
Smurfylude's Avatar
The fidanza has two Marks, TDC and a 15 degree I believe. They are notch marks not colored like the OEM
Old May 16, 2005 | 04:52 PM
951dc5's Avatar
Default Re: (Sushi X)
haha yeah TDC i mean.. so does it really matters if it's aligned with any three marks..as long it's in between those 3 marks?
On the flywheel.. by shooting a timing light gun, is there only one mark or more? all i see is that + mark
Old Jan 7, 2012 | 09:53 PM
sesso's Avatar
I know this is an old thread but what if there is only 1 mark on. The flywheel. ;(
Old Jan 7, 2012 | 11:07 PM
holmesnmanny's Avatar
If for some strange reason there is only one mark, take off the valve cover and set the engine to TDC then look at the mark on the flywheel and pray it's not there. That will mean the mark is 15 degrees BTDC . Then move the engine so the mark lines up and then just use a marker to mark the teeth like I do so it becomes easier to see, then set the timing.
Peter Brady onlyonweekndz
Dec 25, 2007 11:18 AM
pcguy760
May 21, 2007 07:53 AM
jdm00civicex
Sep 27, 2006 09:00 PM
preluder
May 19, 2003 07:00 AM
