what should i go with vafc or e-manage
Old May 15, 2005 | 08:29 AM
kingofkingz's Avatar
Default what should i go with vafc or e-manage
i was woundering what type of fuel unit i should go with the apex-i vafc or the greddy e-manage, they both seem to do the same thing. witch unit would be better to run with 310cc injectors with a t3 turbo on a d16y8. what do you guys think, let me know.
Old May 15, 2005 | 08:31 AM
getnasty's Avatar
Default Re: what should i go with vafc or e-manage (kingofkingz)
NEITHER THEY ARE BOTH JUNK. get hondata or even uberdata
Old May 15, 2005 | 10:07 AM
Terrible One's Avatar
Default Re: what should i go with vafc or e-manage (bottle fed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">NEITHER THEY ARE BOTH JUNK. get hondata or even uberdata</TD></TR></TABLE>
yup what this dude said. but uberdata would have to be my choice. its more of a DIY management that works hella good! do a search on uberdata.
Old May 15, 2005 | 10:14 AM
s2kdre's Avatar
Default Re: what should i go with vafc or e-manage (Terrible One)
they are good for low boost, but people have had bad luck with them so they talk **** about them. And when they blow their motors they blame it on the afc, if its tunned right you'll never have a problem.
Old May 15, 2005 | 10:55 AM
TheShodan's Avatar
Moderator
I've help tuned 4-5 cars fine w/ E-manage. They aren't junk, just not what people think it is going to be.
The difference mainly is that the AFC doesn't have the ability to adjust ignition or timing as the e-manage does, nor does it allow you to use a correction factor to have larger injector sizes.
It's not a bad system at all, you just have to know what to do.
Black Si's Avatar
i had the emanage and made 344whp and it was a great lower budget setup and you dont need to keep burning chips
Old May 15, 2005 | 11:26 AM
SOHC_MShue's Avatar
Default Re: (Black Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Si &raquo;</TD></TR><TR><TD CLASS="quote">i had the emanage and made 344whp and it was a great lower budget setup and you dont need to keep burning chips</TD></TR></TABLE>
there is no need to keep burning chips with hondata or uberdata either. I use the ostrich for uberdata and the only time I have to burn a chip is for a final hard copy tune. I can make changes with the car running using the ostrich.
Old May 15, 2005 | 11:33 AM
evilone's Avatar
Default Re: (SOHC_MShue)
emanage works well for the price but you have to use the support tool to really utilize it.
Old May 15, 2005 | 11:50 AM
i will probably go with the emanage, im only running 8 psi, its good enough for me.
Old May 15, 2005 | 01:08 PM
how hard is it to use the support on the emanage.
Old May 15, 2005 | 08:52 PM
evilone's Avatar
not too hard, but the emanage directions suck. but if you spend some time with it , it is kinda self explanatory
BoB44
13
Jul 1, 2007 05:07 AM
Boarderx192
Feb 4, 2006 02:34 PM
93h22a1vtec
Dec 20, 2005 11:40 AM
jdm_loser
Jun 23, 2004 10:51 AM
Rhythm Racer
11
May 24, 2003 10:21 PM
