ignition timing in high vacuum on race gas... what to do with it???
Old May 15, 2005 | 07:29 AM
mrx's Avatar
mrx
Default ignition timing in high vacuum on race gas... what to do with it???
Hallo,
what do you guys do with the high vacuum part of the ignition maps when using race gas?
i.e. think about the following situation:
you tune an engine with race gas and advance the ignition at athmosphere pressure for lets say 4-6° over the stock value to reach MBTT, what do you do with the high vacuum section of the igniton map?
- do you rise them also 4-6° to get a smooth looking map
- or do you let them on stock values.
i ask because in a stock map you have allready ~30° of timing in this section and i think increating the advance in this area is useless because thats not the area where you product torque so why should i add timing there?!
but if i don't change the values in this are the map looks very bumpy and has a huge step depending on how much i advanced the timing in the atmosphere and boost section.
how far can you typicaly go with the timing in the high vacuum areas? what is dangerous to the engine? (i know that is very general but i think there is a general rule of how far i can go)
Old May 16, 2005 | 01:45 AM
mrx's Avatar
mrx
Default Re: ignition timing in high vacuum on race gas... what to do with it??? (mrx)
noone?
anton_
Engine Management and Tuning
May 20, 2008 11:07 PM
CRXdan
Nov 26, 2004 09:49 PM
cjblmr
Nov 12, 2002 06:41 AM
b00stedbyFastrax
Sep 1, 2002 06:39 AM
