Help with MPFI...I have triple checked everything
Old May 14, 2005 | 04:15 PM
No-Gi's Avatar
Default Help with MPFI...I have triple checked everything
I did a MPFI conversion on my 91DX Hatch. I am getting code 16 and after trobleshooting I realized that injectors 2 and 4 are not working. I have checked my wiring about 20 times to make sure that Inj #2 is plugged in at A3 and that Inj # is at A7 and they still dont work. Inj #1 and 3 are working just fine. I really dont know what else to check. Any ideas? I really need to get the car running because my other car was totaled. BTW, I already put 2 new injectors in and still no luck.
The cars starts and runs but it is running in limp mode.
I checked for continuity and there are no problems there. The injectors just dont have power going to them. This sucks. I have a conversion harness I purchased from the rywire site, should I have switched wires around
Old May 14, 2005 | 04:44 PM
No-Gi's Avatar
Default Re: Help with MPFI...I have triple checked everything (3_South)
When the manual asks if there is battery voltage are they refering to 12V?
Old May 14, 2005 | 05:22 PM
DeadVet's Avatar
yes 12 volts, when the injectors are firing the ecu makes and breaks connection to ground similar to a coil firing.
Old May 15, 2005 | 07:01 AM
No-Gi's Avatar
Default Re: Help with MPFI...I have triple checked everything (1TurboHatch)
Do I have to checjk this while the engine is on or justy have the key in the ignition at III.
ever'sneighborhood
Feb 24, 2009 07:45 PM
2point3h22lude
Sep 6, 2005 02:38 PM
bootlegcivic
Aug 6, 2005 10:07 PM
No-Gi
16
May 22, 2005 07:29 PM
No-Gi
May 21, 2005 05:07 PM
