how/where to disconnect hydro clutch
Old May 14, 2005 | 03:22 PM
vtecpoweredsol's Avatar
Default how/where to disconnect hydro clutch
how/where should i remove the lines to my hydraulic clutch?
Old May 14, 2005 | 03:29 PM
MonkeyBoy668's Avatar
Default Re: how/where to disconnect hydro clutch (vtecpoweredsol)
To my knowledge you don't have to remove the lines to your hydro clutch to work on it - you just remove the slave cylinder from the outside of the transmission housing, leaving the hydraulic system sealed.
'course I suppose it all depends on what you want to do...
Old May 14, 2005 | 03:38 PM
Default Re: how/where to disconnect hydro clutch (MonkeyBoy668)
kthnx swap time
Old May 14, 2005 | 03:50 PM
Luserkid's Avatar
Your swapping out the motor? disconnect where the rubber line meets the steel line.
Old May 14, 2005 | 07:15 PM
Default Re: how/where to disconnect hydro clutch (Luserkid)
wont all the hydraulic fluid leak out tho?
90civicbns
Aug 1, 2013 12:50 PM
sl0whatch
Jun 13, 2010 01:00 PM
matryx
May 5, 2008 06:08 PM
scartail
Aug 29, 2005 03:11 PM
jdmcivicferio
Apr 13, 2004 02:15 PM
