Need Help Tried Everything!!
Ok for the past four weeks i have been having idle problems, i have read all the posts about IACv and FITV's but i have had no luck. The idle on my car intermittanlty bounces from 600 - 800 (Prelude Vtec SI 1992). The car drives fine with no problems but when it is warm after about 15 mins of driving the idle will start fluctuating. I have taken the IACV unit off and cleaned it with carb cleaner and i have ran carb cleaner through the whole car and injector cleaner. i have cjecked for Vacum leaks and cannot find any. I have checked the voltage on my battery and it is running at 14.3volts. The only thing i have not checked is the FITV. Can anybody suggest anything else i can try before i take into a garage. Could it be the alternator?? or the FITV. I have also tried plugging the bottom whole on the intake while the idle is bouncing and it makes no difference.
Thanks
Rob
Thanks
Rob
From: united states of mexico and yes ladies i am, available
man you dont use carb cleaner on a fuel injected car
when my bro's sh did the same thing we tried every thing so we took it to a place here called hondamotive and they took off his intake manifold and cleaned everything out they said it was dirt messing with the sensors and it never did it again
