normal motor compression ratio test psi?!
Old May 14, 2005 | 12:59 PM
petermike's Avatar
Default normal motor compression ratio test psi?!
I bought a 2000 honda civic SiR (Can)US Si) the motor is the b16a2 and at this time honda performed a compression resulting 185-185-180-185 (psi) the mecano said this is almost perfect .. at this time i was on the full honda warranty .. and then 1 month after.. i realized that it's leaking or burning like..1 L or more.. of motor oil.. in 1000km (600 miles) so.. there is a problem.. because the motor burn a lot of oil.. but the inspection was.. ahh it"s perfect !! buy it ! :s
now honda say ahhh... you are on the extended warranty you need all receipt of oil change since the god creation wtf!?
what is the NORMAL compression in PSI for a 2000 b16a2 motor with 90 000KM (54 000Miles) ?? 220psi or.. less???
Old May 14, 2005 | 01:17 PM
Kyles ej1's Avatar
Default Re: normal motor compression ratio test psi?! (petermike)
thats perfect compression, thats where its suppose to be and also in compression its not always about the compression its about consitancy
Old May 14, 2005 | 01:24 PM
Morning Call's Avatar
yeah those numbers are good
compression is always different in every car... atmospheric changes, how high from sea level/below sea level
its never the same as someone elses really...
as long as your compression is the same across each piston your fine.. and yours are fine.. 185's with one 180.. thats fine
Old May 14, 2005 | 01:31 PM
petermike's Avatar
185 is perfect compression for a b16a2? its suppose to be a high compression engine..
Old May 14, 2005 | 01:32 PM
petermike's Avatar
Default Re: (petermike)
well ok thank you, that's seam to bo a good explanation.. so.. compression ring are ok.. so the leak can be another ring on piston.. maybe
Old May 14, 2005 | 01:40 PM
Kyles ej1's Avatar
oil rings have nothing to do with compression. u can have perfect compression and a worn oil ring, a compression test wont show it
sirguy01
Jul 6, 2006 09:03 PM
floatfisher
May 30, 2006 10:09 PM
sjracer
Jan 21, 2003 03:28 AM
LsTurbo91
May 12, 2002 07:52 PM
