da teg a bit shakey?
I have a 92 teg with a b20/vtec swap.. there is no power steering or ac, and on the freeway the steering wheel shakes a little bit, at higher speeds over 85 the whole car shakes some... its on weapon-r coilovers, not dropped that much really, anyone have this same problem or know what the problem could be?
any suggestions are appreciated
As long as I dont have to take out any more Metal Gears
could be a number of things. Most likely an unbalanced tire, or the car needs an alignment. If that doesnt fix it, it could be a bent rim, a bad tire, warped brake rotors, bad shocks. But try the tire balance or aligment first, it is most likely as simple as that.
1-tires not balanced properly
2-loose steering rack mounting bolts
3-bad steering rack
when u brake, does the steering wheel shake?
3-bad steering rack
the steering wheel doesnt shake anymore that usual when i brake, when i first got the car it had slotted rotors that warped and it shook badly when i braked, not i just have regular brembos so, i dont think its warped rotors, but i did just get the tires rotated so maybe an unbalanced one got put in the front or somethin?
R-Lug
25
Dec 9, 2005 04:27 PM
