How to test a turbo see if its working condition ??
Old May 13, 2005 | 11:59 PM
bossman032's Avatar
Default How to test a turbo see if its working condition ??
Guys how do you test a turbo??
I wanna see if mine is in working condition. I spin the turbine it spins fine but has a light noise like its scratching or dirt..
I used a blow dryer and it spins fine no problems..
any particular way I can test it..
thx
bossman
Old May 14, 2005 | 09:00 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: How to test a turbo see if its working condition ?? (bossman032)
You can also pour some oil into the oil feed hole, plug both sides (feed and return) and see if oil leaks out from the turbine side and compressor side while spinning the shaft. If it does leak then you have a bad seal, bad journal bearing or other internal parts damaged.
94CivicSi
Mar 31, 2016 03:56 PM
steve96accord
Jun 30, 2006 09:40 PM
zojirushi
Nov 14, 2001 08:36 PM
Honda Hick
Oct 27, 2001 11:25 AM
