garrett turbo
Old May 13, 2005 | 10:35 PM
redlseg's Avatar
Default garrett turbo
i recently bought a used garrett turbo. theres the oil feed line and then theres the oil return line. but i'm trying to figure out what the other two holes are i know one is a vaccum but i'm not sure what the other one is for. the oil lines and these two holes are between the compressor and the exhaust housing. i dont know if i made any sense but can someone please help me figure out my problem. thanx in advance
Old May 13, 2005 | 10:51 PM
SOHCmaster's Avatar
coolant lines.. You dont have to use em if you dont want to.
Old May 14, 2005 | 08:33 AM
redlseg's Avatar
Default Re: (PK SPEED)
are u sure, i just dont want to crack or break anything if i dont use them? also thanx for replying
Old May 14, 2005 | 08:35 AM
SSBPGSR's Avatar
Default Re: (h-tman)
yea they are for coolant, oil and coolant are the only holes that *should* be in the cartrage of the turbo. good luck
Old May 14, 2005 | 08:41 AM
redlseg's Avatar
Default Re: (SSBPGSR)
so what should i do plug them up or use them? i have no idea where to hook up the coolent line to. i myself really dont want to use them. what should i do? thanks
Old May 14, 2005 | 08:43 AM
SSBPGSR's Avatar
you dont have to plug them up, the coolant and oil passages in the turbo are seperated.
Old May 14, 2005 | 08:49 AM
redlseg's Avatar
so if i dont use the coolent line my turbo will be safe right? sorry for asking so many question i just want to make sure it will be ok
Old May 14, 2005 | 09:34 AM
redlseg's Avatar
Old May 14, 2005 | 11:19 AM
redlseg's Avatar
can someone please help me out. this is all i have left to do on my turbo setup
Old May 14, 2005 | 11:24 AM
SSBPGSR's Avatar
yes it will be safe. coolant is just to cool the turbo, let the car idle for about 2 minutes after you drive it and it will be fine without coolant
Old May 14, 2005 | 11:30 AM
redlseg's Avatar
thanks
Old May 14, 2005 | 11:31 AM
SSBPGSR's Avatar
np
Old May 14, 2005 | 12:13 PM
Under_Pressure's Avatar
Why would you not want to use the coolent lines??? If you have them use them its not hard to setup. A cooler turbo is always better, but then again its up to you, it wont hurt your turbo but the way i see it is it doesent hurt you using it either
Old May 14, 2005 | 06:38 PM
SOHCmaster's Avatar
I been running a eclipse T25 for ovrer 2 years with no coolant lines hooked up, Ill snap a photo right now and show you.. Nothing will be dammaged by not running the coolant lines..Its just a hallow cavity in there in/out
Old May 14, 2005 | 09:52 PM
a1320addict's Avatar
if i were you id go and run some lines to the cartridge
i spoke to garrett recently at springnationals at englishtown and asked if it was 100% neccesaryy to use the water cool fittings.
from what they told me, on smaller turbos...like straight t3s and down....the turbo is spinng so much that the standard oiling of the unit is no enough. basically he said it gets so freaking hot in there that you can damage the turbo. thats just what he said.
i would run em..it cant hurt
Old May 14, 2005 | 10:02 PM
SSBPGSR's Avatar
Default Re: (yehiknowrite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">if i were you id go and run some lines to the cartridge
i would run em..it cant hurt</TD></TR></TABLE>
i would def run them as well if this were me.
Old May 15, 2005 | 04:32 AM
DelSol-B-18's Avatar
Just run your coolant lines through the turbo,
Use the line that comes from your rad to the motor, but go to the turbo, then to the motor on hold is in, the other is out, it is simple.. Better to have a COOL turbo then one that is too hot, U willl gain more out of it this way also. U could also get a intercooler and set up..
roachsboosted16
Oct 3, 2010 10:24 AM
boosted_zc
Jul 13, 2003 09:02 PM
It's*BOLO!!
Mar 30, 2003 03:19 PM
thejdmkid
Jan 13, 2003 06:38 AM
Scott - 93HB Si
Sep 4, 2002 04:14 AM
