HELP!! Can't get crank bolt off.
Old May 13, 2005 | 10:22 PM
uncald4's Avatar
Default HELP!! Can't get crank bolt off.
I bought the Moroso crank pulley wrench. It works great for holding the pulley in place. But I've broken too many tools trying to back out the bolt that holds it to the crank. That bitch is snug. Anyone else taken off their crank pully before?
Old May 13, 2005 | 10:29 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: HELP!! Can't get crank bolt off. (uncald4)
all of the toruqe is being lost in the extensions. Use a deep 17 or 19- depending on engine, and a breaker bar. Lay on your back and use your leg...works everytime for me at home
Old May 13, 2005 | 10:34 PM
uncald4's Avatar
Default Re: HELP!! Can't get crank bolt off. (Evs-One)
My deep well 17mm is just shy of getting a wrench on it. I'll try it again tomorrow. I need to go buy a good breaker bar.
Old May 13, 2005 | 10:37 PM
nocturnaldragon's Avatar
If you use those extension you lose a lot if not all your torgue right there. Your gonna end up needing an 8ft cheater bar with two big guys jumping on it to break it lose like that. Well thats what I did
Btw: Thanks for getting the proper tool to get that thing off the right way. I cant begine to tell you how sick and tired I am of ppl breaking something else because they dont get that tool to hold the pully propperly.
Old May 13, 2005 | 10:38 PM
Andres-eh2's Avatar
what i do is heat it up with a torch for about 5-10 minutes until the bolt gets almost red.
Old May 13, 2005 | 10:45 PM
uncald4's Avatar
Default Re: (Andres-eh2)
My deep well socket is too short without an extension!!
Old May 13, 2005 | 10:49 PM
uncald4's Avatar
Default Re: (uncald4)
Is this bolt reverse threaded? Impact wrench?
Old May 13, 2005 | 10:52 PM
Morning Call's Avatar
impact wrench is your friend
buddy took mine off no problem with one
Old May 14, 2005 | 01:25 AM
TurboEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncald4 &raquo;</TD></TR><TR><TD CLASS="quote">Is this bolt reverse threaded? Impact wrench?</TD></TR></TABLE>
no it isnt,
get the 1 and 1/2 inch extension and a breaker bar and go at it, unless u can get ur hand on a nice impact.
Old May 14, 2005 | 07:09 AM
boostmywankle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">what i do is heat it up with a torch for about 5-10 minutes until the bolt gets almost red. </TD></TR></TABLE>
when i did mine, i had tried getting mine off forever, then i hit it with some heat, and she broke loose!
Old May 14, 2005 | 07:21 AM
TallKyle's Avatar
Default Re: (96teggyls)
put the car back on the ground put it in 5th gear and use ebrake and 17 mm with a breaker bar. works wonders.
Old May 14, 2005 | 07:37 AM
racerpat94's Avatar
3/4 in impact will pop it off quickly. 3/8-1/2 wont have enouhg torque. most decent shops will break it loose for you for around $10, then hand tighten it so you can drive home.
Old May 14, 2005 | 07:24 PM
Hurricane's Avatar
Default Re: (racerpat94)
3/4 Impact or the special tool made to hold the pulley while you break the bolt loose, have also heard of people holding the pulley with a belt wrench.
Old May 14, 2005 | 10:40 PM
dohcVTECeg2's Avatar
Default Re: (Hurricane)
you have to jam the flywheel in order to get it taken off
Old May 14, 2005 | 11:33 PM
GZR4DR's Avatar
Default Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">you have to jam the flywheel in order to get it taken off</TD></TR></TABLE>
That is what I sometimes do however a good impact wrench will take the bolt off everytime.
Old May 14, 2005 | 11:38 PM
uncald4's Avatar
Default Re: (GZR4DR)
Jam the flywheel? I have a crankshaft pully wrench. It came off with ease when I used a 1/2 inch breaker. I put it all back together. It runs awesome!!
Thanks for all the help guys. Definately appreciated!!
Old May 15, 2005 | 05:35 AM
Dan GSR's Avatar
some crank bolts can become very stubborn
I had one that was a PITA even with my 800ft/lb impact gun
Old May 15, 2005 | 05:59 AM
d16rice's Avatar
I had that same problem about a month ago.
I tried 300fpt impact wrench and even a 600fpt impact wrench with no results.
Eventually what I did was this:
1.Spray the crank bolt with bolt removal lube.
2.Remove the starter
3.Stick a flathead screw driver in the flywheel teeth and have some one hold it there.
4.Get a breaker bar with an extended handle and turn it counterclockwise.
Go here if you need more info:
<A HREF="https://honda-tech.com/zerothread?id=1193016&page=2
" TARGET="_blank">https://honda-tech.com/zerothre...e=2
</A>
Old May 15, 2005 | 06:29 AM
99blackcivicSi's Avatar
Default Re: HELP!! Can't get crank bolt off. (d16rice)
my 1/2 impact gun takes off all the crank pulleys i need it too, i have had one or two back when i was working here in my little shop that were real stubburn and i had a hard time getting off, i locked the flywheel with the snap on tool, and it came off with my breaker bar and a jackhandle for leverage
Old May 15, 2005 | 06:31 AM
Radyjr's Avatar
i bought a crank bolt remover from summitracing.com about 4 months ago to remove the damn bolt and i won't use another tool for my cbolt then my honda/acura crankbolt remover
c61lude
Dec 2, 2018 12:06 PM
mattthethug
10
Oct 28, 2010 08:35 PM
judunty84
27
Apr 5, 2007 12:07 PM
Teg_93
Jan 15, 2007 06:55 AM
Draggin99Si
59
Feb 20, 2005 11:59 AM
