Adding fuel with FPR causing a popping sound
I recently replaced my crower 402s and did a valve adjustment. My NA setup is making a popping sound when im trying to add more fuel with the FPR and sounds like its running really sluggish on idle. I didn't take it out for a spin yet because it doesn't sound close to anything normal. I'm also getting a code 11. According to helms diagnostics codes, its not even listed. I have a p28 chipped running on a stock GSR basemap.
What could be causing the popping sound? Any advice would help.
the car feels like it wants to shutdown every second, but it keeps going. Kinda a pause once every second(run, choke, run, choke, run, choke, runs, choke, runs... dies out). Anyone know what this could possibly be?
You should be adjusting fuel pressure with the vacuum line off. It sounds as if you're in need of some real tuning, rather than some DIY fuel pressure adjustments.
what program r u run n on your ecu? r u run n UBERDAT/CROME. if u r then ur car is run n crazy rich and u need to lean it out.
im having a similar problem with my turbo ls/vtec i just put a new turbo on cause my old was bad and now im trying to adjjust the pressure and it;s giving me problems when i take it out to drive soon as it builds up a lil boost the car wants to shut down im curious too
ne advice
ne advice
el_toro_de_magnifico
Mar 23, 2008 04:20 PM
