warped block......
Old May 13, 2005 | 06:49 PM
sik_sol's Avatar
B A N N E D
Default warped block......
ok, the set up is an all motor ls/vtec. b16 p30 head, b18b block.
there is a leak where the oil literally runs out of the motor on the front passengers side corner where the block and head meet. the vtec solenoid gasket, cam seal, valve cover gasket, and all the components on the distributor side, including distributor gasket have been checked for leaks.
it's gone through 3 different head gaskets, 2 OEM, and 1 cometic high pressure xtreme head gasket. the head has been milled, so i'd ASSUME that would elimate any threat of it being the head thats warped.
i bought the block used, and am wondering if it was possibly warped....the only other conclusion i can come up with is the oil feed line on the head that was tapped and plugged professionally.....
just wondering if anyone else had any problems related to this, before i buy another block and do it all over. this is the first mileage the block has seen while in my possession...
someone also mentioned decking it, thats the same as milling is to the head right?
thanks in advance.....
Modified by sik_sol at 8:24 PM 5/13/2005
Old May 14, 2005 | 04:36 AM
Chiovnidca's Avatar
Default Re: warped block...... (sik_sol)
Have you checked it with a straight edge?
Old May 14, 2005 | 07:42 AM
rainforest's Avatar
Default Re: warped block...... (Chiovnidca)
buy a machinist straight edge and a good set of feeler gauges and pu the straight edge across the block at an 2angles making an x measure the warpage by fitting a feeler gauge under the straight-edge it should be no more than 0.08mm
Old May 18, 2005 | 06:07 AM
sik_sol's Avatar
B A N N E D
man, wouldnt u think if u took it to a shop to have everything dipped and the oil feed hole plugged, they would think to check to see if it was warped there??
man im really not looking forward to tearing that head off again to see if thats what it is...
anybody have a decked b18 block for sale??? ><
hatchet_honda
May 16, 2009 02:28 PM
pooRmansss
Feb 19, 2009 03:24 PM
ALL MOTOR DA
11
May 1, 2006 02:48 PM
sik_sol
Jun 11, 2005 11:20 PM
C4wrx
Aug 4, 2002 06:23 PM
