Exhaust manifold studs
Old May 13, 2005 | 06:46 PM
PlayDepot's Avatar
Default Exhaust manifold studs
Ok i just picked up a civic about 2 hours ago (92 4 door). My friend helped me gut the **** outta it. So the only things left are the 2 passenger seats and the dash. Mechanically nothings wrong with it besides maybe a few tune up issues. It needs exhaust, it ends where after the resonator where it makes that 90deg. turn. Also heres my main question. Because i do plan to turbo this d-series. One of the exhaust manifold studs snapped off when the prevous owener attempted to take it off. Well he was way off, is there a way to get this thing out and put a new one in? Im not sure on it.
Old May 13, 2005 | 07:22 PM
longbeachpurplecivic's Avatar
Default Re: Exhaust manifold studs (PlayDepot)
is it completely snapped offf? (lined up with the head?) your able to twist it out if it got some left on it and either put another stud in or just put in a bolt 10,12,14 bolt, forgot which one
Old May 13, 2005 | 08:50 PM
PlayDepot's Avatar
Default Re: Exhaust manifold studs (longbeachpurplecivic)
No its level with the manifold on right now. So theres prolly about a quarter inch left in it.
Old May 13, 2005 | 11:00 PM
SOHCmaster's Avatar
Gonna have to drill it all out and tap new threads and use a different stud of some sort. I dont think a remover tool is gonna get it out, cuz I bet its tight as hell.. Good luck
Old May 14, 2005 | 02:50 AM
take off the headers, get a gator grip or whatver and unscrew it ive seen it done, no need for drilling.. then replace with another stud or a bolt
Old May 14, 2005 | 07:48 AM
rainforest's Avatar
do it the right way buy a stud remover tool there cheap and all you will need is 1 8mm stud remover tool. if there is a1/4 in left out you will beable to get it out. it is a socket that wraps around the stud then you ratchet it out
Old May 14, 2005 | 08:03 AM
PlayDepot's Avatar
Default Re: Exhaust manifold studs (rainforest)
that sounds better Thanks!
Old May 14, 2005 | 10:04 AM
SOHCmaster's Avatar
My fault I thought the stud was broke flush.. Might be able to lock some vise gripps on it and turn it out, and put a new one in.. sorry.
Old May 14, 2005 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">do it the right way buy a stud remover tool there cheap and all you will need is 1 8mm stud remover tool. if there is a1/4 in left out you will beable to get it out. it is a socket that wraps around the stud then you ratchet it out</TD></TR></TABLE>
i mean whats the "right" way for anything these days.. theres many alternatives to everything, so theres more than one "right" way its all in your mind
Old May 25, 2005 | 09:09 AM
Powered By Garrett's Avatar
Any luck with this Tony? We should work on our cars one of these days. I wanna get my A/C out of my car, doesn't work anyways. Lets go deliver the 240 today and then come back and get to work on our Civics. Hells yea to a 45min complete gut! Hahaha, and yea, i'm sure our neighbors thought it was stolen considering how gutted it was!
Old May 25, 2005 | 09:36 AM
dwnthehatch's Avatar
Default Re: (EGtenchu)
Here's how I fixed mine: https://honda-tech.com/zerothread?id=567450-
8Gomer9
23
Mar 12, 2017 03:05 PM
invader_zim
Jan 24, 2013 09:19 PM
vtec.dc2
Feb 23, 2005 06:12 PM
Pochtecatl
Mar 31, 2004 09:44 AM
EFb18b
Jul 25, 2003 01:15 PM
