NEED HELP IACV already searched..
Old May 13, 2005 | 03:05 PM
716pro's Avatar
Default NEED HELP IACV already searched..
please someone help me, i changed the iac and the computer is still saying that its fucked. I have a 93 ex with a 94 dx motor, I have the dx computer hooked up to it so it dosent throw codes for the vtec. I let the car warm up and it still sucks air in both of the holes in the TB. When i first start the car it bounces from 100 to 2500 up and down till it gets warm, after its warm it idles fine. It idles fine for a minute or two then the iac hole in the throttle body starts suckin in mad air. And so does the cold start on the bottom of the TB. I tried to block them off with foil but they still suck in air. I know they work cause they came off a working head. Also when i drive the car it bogs until it hits 3000 rpm. could this have anything to do with the IAC suckin in all that air. Some times i cant get the car to to go WOT it only goes to 2000 and bounces down the up to 2000 over and over. Oh ya i pluged the holes with my fingers it made it idle fine but like i said after it warms up you can hear the iac sucking air like crazy. Please help before i take a hammer to my car.
Old May 13, 2005 | 09:54 PM
716pro's Avatar
Default Re: NEED HELP IACV already searched.. (716pro)
please someone say something.
Old May 13, 2005 | 10:56 PM
SOHCmaster's Avatar
shoot some WD40 inthe hole and all problems are solved for a month or two. Thats the only way I can cure mine. I got a bran new one from Honda $130.00 and still issues, so I shot WD40 inside it and was back to all systems go...
Old May 14, 2005 | 07:36 AM
716pro's Avatar
Default Re: (PK SPEED)
willl try that today, but why does the car bog when i try to drive it? Ya think its getting to much air, thats what it sounds like when the IAC is still suckin air after its warmed up?
Old May 14, 2005 | 08:39 AM
SOHCmaster's Avatar
Default Re: (716pro)
I never had mine bog out like you describe, just irratic rpms due to IACV.. Wonder if you have some other problems as well....
Old May 14, 2005 | 02:58 PM
716pro's Avatar
yup
Old May 19, 2005 | 07:11 PM
716pro's Avatar
anyone have any ideas
Old May 20, 2005 | 08:37 AM
PrettyLude's Avatar
you sure its the iacv? it sounds like the fitv, when ur car is warm its not supposed to be sucking in air anymore, that might be ur problem right there
Old May 20, 2005 | 02:27 PM
716pro's Avatar
Default Re: (PrettyLude)
well i changed both of them, and it still sucks air in the iac and fitv holes in the throttle body after the car is warmed up. so i dont know what the prob. is
Old May 21, 2005 | 08:31 PM
PrettyLude's Avatar
bled all the bubbles out the coolant
Old May 21, 2005 | 09:44 PM
716pro's Avatar
ya
Old Jun 2, 2005 | 03:52 PM
716pro's Avatar
cahnged a third IAC and still does the same thing. Still succks air in the hole in the TB. Unplug it and the idle drops but itt still sucks air up. Could it be electrical?
Old Jun 2, 2005 | 05:42 PM
716pro's Avatar
Old Jun 2, 2005 | 06:27 PM
SOHCmaster's Avatar
check voltage with check engine light clean and running good, then check voltage with car acting up w/multi meter. see if there is any differance ? This IACV issue sucks, I been dealing with off and on issues for 2+years with this damn sensor. For me some days are good some days are bad. I do notice when its hot outside I get the problem more so.. Did you lube it up yet, any help or no ?
Old Jun 2, 2005 | 07:11 PM
716pro's Avatar
sprayed the **** out of it with everything. Will check the voltage. Before i go any further the motor is a dx but the wire harness is a ex the motor tha was in the car was a sohc ex motor but it was switched and so was the comp. no codes for the vtec just the iac does that help?
Old Jun 2, 2005 | 08:23 PM
SOHCmaster's Avatar
DX/EX shouldnt matter !! I was seriously thinking the ecu on mine has to have some kind of malfunction, havent swapped yet to see if this was true. Have you swapped ecu yet to confirm this ?
This IACV issue sucks *****, good luck with your problem, keep tabs w/me if you ever find answers to this mystery, seriously..
Old Jun 2, 2005 | 09:20 PM
716pro's Avatar
there was a ex motor in there before i got the car they put a dx moyor in cause the ex head blew, the used the ex wireharnessand left the p28 ecu to run the car, i changed the ecu to a dx po6 or a po5 not sure but it still does the same ****, throws the code for the iac (code 14) can the wire harness have anything to do wit this? Can i run the wires directly to the ecu from the iac, will that work? i am gonna take a hammer to the ****** car real soon, PLEASE HELP>..............
Old Jun 2, 2005 | 11:08 PM
SOHCmaster's Avatar
hell yeah re-wire em and see if it works, cant hurt you know what I mean. Now your ecu story is starting to make more sence.
Key Enzyme
Feb 15, 2013 06:08 AM
JJexpress
May 19, 2009 03:16 PM
HamiltonRex
Apr 21, 2006 09:57 PM
KeithsDAteg
Nov 19, 2004 12:34 PM
Vic Nyce
Dec 23, 2001 02:54 PM
