Engine stand bolts
Old May 13, 2005 | 02:08 PM
ildknyli's Avatar
Default Engine stand bolts
I just went to 3 stores to find bolts but couldn't get the right ones. The two that I got, that go into the block are 5 grade but they would go in about an inch. I have tranny bolts (8 grade) but they only go in about a 1/4 inch.
I was wondering if I should use the 5 grade bolts because they go in an inch. Or should I use the tranny bolts that only go in a 1/4 inch? Which would be the safer route not damaging something if it sits there a while?
Also the two bottom bolts that go all the way through with nuts and washers are 8 grade too.
Old May 13, 2005 | 05:12 PM
Chiovnidca's Avatar
Default Re: Engine stand bolts (ildknyli)
I would use the longer ones.
Old May 13, 2005 | 05:43 PM
WestCoRacer's Avatar
Default Re: Engine stand bolts (Chiovnidca)
You want to go in at least one inch and use all 4 bolts. 2 would go all the way thru the block and put a nut on the other end. You especially need all 4 if you are bolting on the head on the stand.
Old May 15, 2005 | 08:46 AM
ildknyli's Avatar
Default Re: Engine stand bolts (WestCoRacer)
Would the 5 grade bolts hold the weight of the block, head, and maybe some turbo stuff? Or should I still go on the search of some 8 grade?
Old May 15, 2005 | 09:19 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Would the 5 grade bolts hold the weight of the block, head, and maybe some turbo stuff? </TD></TR></TABLE>
Yes.
Old May 15, 2005 | 09:55 AM
biotech0123's Avatar
Im using the tranny bolts on top now and ace hardware bolts and nuts on the bottom.
Old May 15, 2005 | 11:43 AM
ildknyli's Avatar
Default Re: Engine stand bolts (biotech0123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biotech0123 &raquo;</TD></TR><TR><TD CLASS="quote">Im using the tranny bolts on top now and ace hardware bolts and nuts on the bottom.</TD></TR></TABLE>
with mine the tranny bolts only go in about a 1/4 of an inch.
Old May 15, 2005 | 09:13 PM
b-series right? Might be the stand your using also, to be safe use just use the same grade as the tranny bolts except longer.
Old May 16, 2005 | 02:10 PM
ildknyli's Avatar
Yea Ill have to go find some. A lot of places don't even come close to having them.
Thanks for all the help
B_Swapped93
Sep 10, 2014 04:26 PM
-Darren-
Jun 15, 2006 10:10 PM
jcarothers
Jun 2, 2004 09:59 PM
ChrisDaun
May 13, 2003 06:11 PM
civicmatt
Nov 14, 2002 11:13 AM
