Having Problems
Old May 13, 2005 | 02:07 PM
Mr_Moos's Avatar
Default Having Problems
Ok the car
92 Si w/ B20
Problems
Its overheating the temp guage is always moving up and down from like 3/4 to 1/2 then back up again
Flushed system
changed thermostat still does it?
Also the car stutters when im driving like it just tries to die out?
Plz help
Old May 13, 2005 | 03:26 PM
Hurricane's Avatar
Default Re: Having Problems (Mr_Moos)
headgasket or just airbubbles in the system?
Old May 13, 2005 | 03:31 PM
fasthatchb18c1's Avatar
you could be running real lean or having dizzy problems
Old May 13, 2005 | 09:32 PM
Mr_Moos's Avatar
Default Re: Having Problems (fasthatchb18c1)
wouldnt head gasket cause white smoke?
How do you check your air fuel ratio w/o a gauge
Old May 13, 2005 | 10:02 PM
97hb's Avatar
I would suspect head gasket. Also might want to check your water pump, impeller blades might have took a dump. Does it stay cool when driving? Whats the fan doing?
Yeah if your getting white smoke its your head gasket check your radiator and see if there is a little oil or check oil for coolant
N0r420cal
13
Aug 25, 2013 01:18 PM
BlackShingo
May 6, 2010 03:56 PM
oaklandwilly
Other Make Vehicles
Jul 27, 2009 08:10 PM
732xghost
Sep 16, 2008 08:56 AM
1strdtko
Apr 27, 2003 05:27 PM
