Cooling problems
Old Apr 24, 2003 | 05:21 PM
1strdtko's Avatar
Default Cooling problems
I have replaced the radiator, thermostat, and hoses. I have to fill the radiator with water every week. I have a closed deck JG bottom end.
Do you think it's the water pump or thermostat temprature switch?
Old Apr 24, 2003 | 05:35 PM
intekragsr's Avatar
Default Re: Cooling problems (1strdtko)
did you bleed for air pockets?
Old Apr 24, 2003 | 06:00 PM
inspyral's Avatar
Default Re: Cooling problems (intekragsr)
So you're burning coolant? Are you sure the headgasket is sealing?
Old Apr 27, 2003 | 01:18 PM
1strdtko's Avatar
Default Re: Cooling problems (inspyral)
maybe a head gasket problem anyone else have a suggestion?
Old Apr 27, 2003 | 01:24 PM
intekragsr's Avatar
well what have you tried so far? Check compression. It probobly your headgasket. Remove the oil cap and look under it. If you see milk under it or white smoke from the exhaust, its the HG.
Check the head for warpage with a straight edge and feeler gauges.
Old Apr 27, 2003 | 02:44 PM
exactvox's Avatar
What if it smokes from the oil breather? Had this problem on a friend's car, white smoke. I think he overboosted his car because I've found the tube from the wastegate to the turbo ripped. Could that be the head gasket too? I've checked for creamy oil, but none was found. Any help would be helpful.
Thanks,
Jay
Old Apr 27, 2003 | 03:07 PM
intekragsr's Avatar
Default Re: Cooling problems (exactvox)
Someone has to correct me if im wrong, but it could be the cracked valve guide? I think thats what its called. or even your pcv.
Old Apr 27, 2003 | 05:27 PM
hybridsol's Avatar
If your loosing coolant, and there are no leaks, there's only one place it goes- combustion chamber. Your head gasket is not sealing.
Been there, done that.
732xghost
Sep 16, 2008 08:56 AM
racerx159
Jul 1, 2005 12:44 PM
Mr_Moos
May 13, 2005 10:02 PM
arielb1
Oct 26, 2004 10:38 PM
GSG2
Jul 27, 2001 06:52 PM
