Need help fast going to dyno this evening!! Code 41, can I still dyno? Also 02 wire conversion probl
I need help quick, I'm going to the dyno in about 2 hours!!!!
Is it ok that I have a CEL for code 41 (02 heater) going to the dyno?
They use their own wideband so I don't think it's that important that I have that CEL.
This will be on a hondata if that matters. It has already been tuned previously, I just made a bunch of changes to my setup and I'm uping the boost some too so I need a re-ture.
IF anyone can help me on the code 41 this is whats wrong:
I'm following the write ups to convert a 7 wire o2 from VX hatchback into a 4 wire o2 sensor. I have four wires on my o2, green, white, black, black.
From the write ups, I gather:
Green wire from actual o2 sensor goes to green/white wire on harness.
blackwire from actual o2 sensor goes to yellow/blackwire on harness.
white wire from actual o2 sensor goes to orange/blue wire on harness.
Other black wire from actual o2 sensor goes to another yellow/black. There are several around the engine bay, I tapped into the one off the passenger shock tower, inside the harness.
I still get code 41, why???
Thanks in advance!!!
Wont you just disable the O2 heater and sensor when you are on the dyno tuning anyhow in the Hondata software?
civicguy395
Oct 30, 2012 03:52 PM
elmalouno
11
Aug 18, 2004 09:06 AM
