Reverse grind?
Old May 13, 2005 | 07:26 AM
Miz101's Avatar
Default Reverse grind?
When I came out of class today I went to put my car into reverse and it would just seem like it was going in about half way and when I would start to take my foot off the clutch it would start to grind. It did that twice. I had to put my car in first gear, creep up a little in the spot and then put it into reverse before it really went into gear. I've noticed that sometimes it won't even go in at all it's almost like there is wall there blocking reverse until I put it into first, creep up a little and then it will go into reverse.
Is this a sign of my clutch going out or a problem with my reverse gear? If I'm correct reverse doesn't have a synchro right?
Old May 13, 2005 | 07:46 AM
NeoGSR's Avatar
Default Re: Reverse grind? (Miz101)
reverse isn't synchronized, so sometimes you just have to let the clutch out and push it back in to get it to line up--just to spin stuff around. happens to me all the time....wouldn't worry about it
Old May 13, 2005 | 08:06 AM
Miz101's Avatar
Default Re: Reverse grind? (NeoGSR)
Ok thanks. I'll try to pump the clutch a little next time.
Old May 13, 2005 | 08:10 AM
UNKNOWN_MEMBER's Avatar
happens to me all the time. I have to go 1st then reverse.
Old May 13, 2005 | 08:15 AM
RicharDC4's Avatar
if your car is still rolling a little bit, putting it in reverse will grind it. happend to me all the time. just make sure you are not moving before you put it in reverse.
Old May 13, 2005 | 08:58 AM
Miz101's Avatar
Default Re: Reverse grind? (RicharDC4)
Thanks all. I just wanted to make sure there was nothing wrong with the car hehe.
Old May 13, 2005 | 09:04 AM
skunked's Avatar
I actually always went into 4th then Reverse as a habbit to avoid the grind. It worked well.
Old May 13, 2005 | 09:13 AM
IntegraSpeed95's Avatar
ya..it happens with me all of the time...not a big deal for me...i dont spend a whole lot of time in reverse haha
Old May 13, 2005 | 09:17 AM
Miz101's Avatar
Default Re: Reverse grind? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">I actually always went into 4th then Reverse as a habbit to avoid the grind. It worked well.</TD></TR></TABLE>
Yes I think I'm going to make it a habbit of going into first before going into reverse from now on.
Old May 13, 2005 | 09:19 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
i go into 3rd, works fine for me. i dont think any reverse gears are synchronized, every car ive owned has been stick and they all did the same thing. it used to aggravate the hell out of me when i first started driving, then my dad showed me the trick.
Old May 13, 2005 | 09:49 AM
Miz101's Avatar
Default Re: Reverse grind? (benb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">i go into 3rd, works fine for me. i dont think any reverse gears are synchronized, every car ive owned has been stick and they all did the same thing. it used to aggravate the hell out of me when i first started driving, then my dad showed me the trick.</TD></TR></TABLE>
Yes it annoys the hell out of me as well that is why I asked. I'm going to try the going into another gear before reverse thing since it seems to work for everyone else!
Old May 13, 2005 | 01:30 PM
The Droogan Leader's Avatar
Now with ultra-violence!
Yah, this is a common issue with Integra's. It's such a bitch having to pump the clutch whenever you want to go into reverse. Sometimes it doesn't happen, but it usually does.
Reverse =
Old May 13, 2005 | 01:43 PM
Moogen Powah's Avatar
Default Re: Reverse grind? (Shin-tegra)
I do this on my DA. It even says to do this in the owner's manual (go in a forward gear then reverse).
Old May 13, 2005 | 01:55 PM
HGZ's Avatar
HGZ
Default Re: Reverse grind? (Moogen Powah)
RTFM.
Old May 13, 2005 | 09:48 PM
ckyguy's Avatar
reverse gear is straight cut, not slanted like your other gears so it's harder to get in sometimes and also creates more noise (the high pitched noise you hear when backing up fast), it's normal, i just shift into 3rd or 4th then try again and it usually goes in.
Old May 14, 2005 | 07:38 AM
Miz101's Avatar
Default Re: (ckyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckyguy &raquo;</TD></TR><TR><TD CLASS="quote">reverse gear is straight cut, not slanted like your other gears so it's harder to get in sometimes and also creates more noise (the high pitched noise you hear when backing up fast), it's normal, i just shift into 3rd or 4th then try again and it usually goes in.</TD></TR></TABLE>
Ah didn't know that is why it made that sound. Thanks
Old May 14, 2005 | 08:16 PM
Rpizzle's Avatar
yea I had a girl blowin me in her driveway, and her parents were pulling up I put my car into reverse and it wouldnt go, so by the time It went, they were behind us and i had to zip up my pants, almost caught my nutz, I hate when the reverse does that ****
Old May 14, 2005 | 08:37 PM
Miz101's Avatar
Default Re: Reverse grind? (Rpizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rpizzle &raquo;</TD></TR><TR><TD CLASS="quote">yea I had a girl blowin me in her driveway, and her parents were pulling up I put my car into reverse and it wouldnt go, so by the time It went, they were behind us and i had to zip up my pants, almost caught my nutz, I hate when the reverse does that ****</TD></TR></TABLE>
That sucks. lol
Old May 14, 2005 | 08:48 PM
WE'VE GOT A BLEEDER!
Old May 15, 2005 | 06:11 AM
thats fookin hilarious.
chocolatesk8er10
Jul 25, 2007 11:24 AM
ChrisSpade
Apr 22, 2006 10:16 PM
KekahaB18
May 15, 2005 09:17 PM
Jeff_B
Dec 10, 2004 09:21 AM
kydragger
Feb 17, 2003 10:55 AM
