What are all these wires? and how to clean this up?
can anyone help me these questions?
Any idea cleaning this up besides a wet towel?
What are these wires? I think #2 and #3 are speaker wires. Should I cut them?
Modified by dchan86 at 9:42 AM 5/13/2005
Modified by dchan86 at 9:43 AM 5/13/2005
#2 is on the right side of the dash near the harness and the ECU.
#3 is red and black speaker wires from the left speakers.
i was thinkign it is suppose to be attached to the radio. good idea, it probably is.
ttt for the insomnaics!
# 1 is the antenna. It's tip is fucked up and you won't be able to use it anymore. Get a flathead screwdriver, remove the 2 screws holding down the antenna to your roof and pull the entire assembly out.
#2 seems to be the speaker wire colors.
#3 is probably also speaker wire since it's coming out of the door crack where the speaker is. Remove the door panel and take a look for yourself. But, those don't seem like OEM colors for speaker wire, so definitely check it out.
