Intake Camshaft broke in half, Intake cam doesn't rotate
Old May 12, 2005 | 09:11 PM
milano2kdc2's Avatar
Default Intake Camshaft broke in half, Intake cam doesn't rotate
Today after I put the cams in, torqued everything to spec, did everything like you're supposed to, I cranked the car, but it wouldnt turn over. I took the valve cover off to discover that the intake cam was snapped by cylinder #3
Anyway, I take those cams out and put in my stock gsr cams. I did everything again and when I was about to slip the timing belt on, I noticed my intake cam wouldn't turn. I tried turning it by the bolt using a lot of force, but it just wouldn't turn. It turned before the other cam snapped in half.
Whats wrong? Belt valves?
They're Ferrera Valves if it matters
thx in advanced.
Old May 12, 2005 | 09:13 PM
Kendall's Avatar
It's possible that it's a valve situation, but if it won't rotate at all, it's possible that one of the cam journals has a problem. How much torque did you tighten them with?
Old May 12, 2005 | 09:17 PM
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">It's possible that it's a valve situation, but if it won't rotate at all, it's possible that one of the cam journals has a problem. How much torque did you tighten them with?</TD></TR></TABLE>
20 ft/lbs
Old May 12, 2005 | 11:01 PM
Rusty Shackleferd's Avatar
Default Re: (milano2kdc2)
were the arrows on the three middle caps pointing toward the cam gears? If so try another torque wrench or maybe just tighen them hand tight and try to spin the crank.
Old May 13, 2005 | 12:50 AM
GOLDBERG's Avatar
Default Re: (Rusty Shackleferd)
what kinda clearances do yah got?each journal
Old May 13, 2005 | 02:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty Shackleferd &raquo;</TD></TR><TR><TD CLASS="quote">were the arrows on the three middle caps pointing toward the cam gears? If so try another torque wrench or maybe just tighen them hand tight and try to spin the crank.</TD></TR></TABLE>
the arrows are pointing towards the cam gear, and the cams won't budge
Old May 13, 2005 | 06:40 AM
smkngsr's Avatar
what you could have done is after the installation is complete is, you should just turn the crank 2x just to see if everything turns smooth, then if everything goes smooth then crank it...at least u know for sure that it does not have any resistance on any of the turns...
Old May 13, 2005 | 07:16 AM
Revhard92si's Avatar
Default Re: (smkngsr)
Also check the distributor to see if the shaft didn't lock up on you. I've seen that before.
Old May 13, 2005 | 07:48 AM
Default Re: (Revhard92si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smkngsr &raquo;</TD></TR><TR><TD CLASS="quote">what you could have done is after the installation is complete is, you should just turn the crank 2x just to see if everything turns smooth, then if everything goes smooth then crank it...at least u know for sure that it does not have any resistance on any of the turns...</TD></TR></TABLE>
i did
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revhard92si &raquo;</TD></TR><TR><TD CLASS="quote">Also check the distributor to see if the shaft didn't lock up on you. I've seen that before.</TD></TR></TABLE>
i can spin the dizzy freely when the cam isnt in there, so its not the dizzy right?
Also, if the motor never turned over, can i still have bent valves?
Modified by milano2kdc2 at 5:09 PM 5/13/2005
Old May 13, 2005 | 12:11 PM
smkngsr's Avatar
wow...thats really strange...i mean, if everything goes smooth i dont see any reason why it will snap specially on initial start up...i know if you did them too tight it can snap but it takes a lot of heat to snap a cams.
Modified by smkngsr at 1:48 PM 5/13/2005
Old May 13, 2005 | 01:15 PM
DelSolDon's Avatar
JW, what kind of cam was it that snapped?
Old May 13, 2005 | 01:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smkngsr &raquo;</TD></TR><TR><TD CLASS="quote">wow...thats really strange...i mean, if everything goes smooth i dont see any reason why it will snap specially on initial start up...i know if you did them too tight it can snap but it takes a lot of heat to snap a cams.
Modified by smkngsr at 1:48 PM 5/13/2005</TD></TR></TABLE>
Thats what I said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">JW, what kind of cam was it that snapped?</TD></TR></TABLE>
I chose not to name the brand because I don't want this to turn into a huge debat about these cams, and no, they're not obx lol
Old May 13, 2005 | 01:35 PM
DelSolDon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milano2kdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
they're not obx lol </TD></TR></TABLE>
kinda what i was thinking. hopefully not honda oem either?
Old May 13, 2005 | 01:39 PM
regamaster's Avatar
Pull the cams out and the spark plugs. Take a 10mm L shaped (brakeline tool) and use the leverage on nut on the rocker arm and see if the valves will move. That is the easiest way unless you have a leakdown tester.
Also is this head completely original ( meaning same head and cam caps.)
I have seen people mix the cam caps with different heads and this occurs.
Old May 13, 2005 | 06:34 PM
RedZone's Avatar
Default Re: (regamaster)
I think a leak down would be your best bet, but it seems odd that the cam doesn't turn.....I have your other cams here and I was looking at them and noticed that the cam cap had put a mark on the cam.....maybe the cam caps are in the wrong spots....double check everything again...and use alot of Assembly lube, I like Synergyn myself, if you need some come by the shop and ill hook you up with some.
crazyguy
Jan 30, 2008 07:52 AM
B18C-Hatch
Sep 6, 2006 10:06 AM
hondapwr
16
Aug 5, 2005 08:51 AM
provo
Oct 28, 2004 07:51 AM
2000fbp
Aug 27, 2003 09:19 PM
