"Chipping/reprogramming" an ECU?
Old May 12, 2005 | 07:27 PM
blah13's Avatar
Default "Chipping/reprogramming" an ECU?
Is it possible to have an ecu reprogrammed to ignore certain sensors? Like the shift lock solenoid for AT's and the electronic load detector? Short story is I throw a code 20 anytime I turn my ignition on, but dont start the car. As long as I start the car it doesnt trip, the ELD is good so grrr.. Any places to ask would be appreciated.
Old May 12, 2005 | 07:47 PM
DocSean's Avatar
Alot of programs remove certain sensors (knock for example) but I am pretty unsure about shift lock solenoids and the other mentioned. I'm sure they can all be removed, but I know a lot of work goes into it.
Old May 12, 2005 | 08:52 PM
drdisco69's Avatar
Default Re: "Chipping/reprogramming" an ECU? (blah13)
Yes, you can disable many different sensors individually. To ignore the AT lockup, you can convert it to manual, and the ELD can be disabled in the rom by chipping the ECU. I can help you with that, or there are others as well. See the link in my sig for more info.
Old May 12, 2005 | 09:15 PM
blah13's Avatar
Default Re: "Chipping/reprogramming" an ECU? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">I can help you with that, or there are others as well. See the link in my sig for more info.</TD></TR></TABLE>
Sweet, I appreciate it. Once I get everything ripped out and figure out what I want done I'll pm you, but we all know how long these "little" projects can take. I just wanted to make sure it could be done before I went ripping crap out.
Old May 13, 2005 | 01:36 AM
96-EJ6 B18C's Avatar
Check out http://www.PGMFI.org for all the details
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
Greg50Lt
Honda Civic (2006 - 2015)
Nov 17, 2007 06:44 PM
eg6madness
Jan 27, 2007 09:02 AM
dbdragstar
Jan 19, 2007 02:47 AM
shreddinryguy
Aug 11, 2005 08:51 AM
