CAN'T SHIFT WITH ITR FRONT SWAY BAR
Old May 12, 2005 | 03:25 PM
krysmagnetic83's Avatar
Default CAN'T SHIFT WITH ITR FRONT SWAY BAR
I got a itr front sway bar for my 97 cx. well i need control arms so i found 97 del sol front lower control arms(flc). well they did not fit when i went to install them. so i took them apart and used the side with the end link mount. i did this on both sides all went great i put the itr bar and end links in all went great. then when i put load on the car the shifter would be really hard to shift. the **** linkage rubbs hard core on the itr bar. any info well help
thanks for your time
im not a noob just forgot my password and devnull@honda-tech.com is no help
Old May 12, 2005 | 03:39 PM
Relic1's Avatar
Default Re: CAN'T SHIFT WITH ITR FRONT SWAY BAR (krysmagnetic83)
you did run the bar OVER the shift linkage right?
pics would help a lot.
Old May 12, 2005 | 03:45 PM
Default Re: CAN'T SHIFT WITH ITR FRONT SWAY BAR (Relic1)
YES PICS ARE THE BEST ILL TRY. the bar is over the linkage does it need to be under
Old May 12, 2005 | 03:51 PM
jeffk182's Avatar
The linkage should be under the bar.
Old May 12, 2005 | 04:39 PM
Default Re: (jeffk182)
it is. what would cause it to rub is it the del sol flca
Old May 12, 2005 | 04:54 PM
jdmspoonpower's Avatar
Default Re: (krysmagnetic83)
maybe you put it on the wrong spot???? or maybe front to back or back to front? thats maybe why ur hitting the linkage...do u have a short shifter?
Old May 13, 2005 | 04:47 PM
Default Re: (jdmspoonpower)
bumb
Old May 18, 2005 | 06:40 PM
i think it my shift linkage its not bent the same as a itr or any other car with a b motor
CRX MASE
Feb 16, 2011 11:06 PM
Buddhist_fist
Nov 10, 2007 04:15 PM
mullet eater
Suspension & Brakes
Oct 18, 2007 09:24 AM
krysmagnetic83
Suspension & Brakes
May 20, 2005 08:23 AM
