dsm injectors, going back to stock?
Old May 12, 2005 | 01:53 PM
FMIDRC Racer's Avatar
Default dsm injectors, going back to stock?
i was running dsm injectors on my turbo z6 motor but now it's in the shop being built and i'm rocking the stock motor again. i still have the resistors wired into my wiring harness. do i need to remove the resistors before i can use the stock obd-1 injectors again?
Old May 12, 2005 | 02:40 PM
-[95cxhatch]-'s Avatar
Default Re: dsm injectors, going back to stock? (FMIDRC Racer)
yea the resistor box wasnt there to begin with make sure you dont forget about the injector seals if you expanded them to fit the dsm injectors
Old May 12, 2005 | 04:29 PM
Default Re: dsm injectors, going back to stock? (-[95cxhatch]-)
i put them in and the obd-1 injectors do work with the resistors still wired up.
Old May 12, 2005 | 08:58 PM
flipsyde's Avatar
b-series injectors dont need the resistor box. you can keep the resistor box in there if you run h22 or h23 injectors.
Old May 13, 2005 | 06:00 PM
Default Re: (flipsyde)
you have no idea what you are talking about.
GT500FTW
Nov 29, 2012 03:10 PM
b17a1crx
Sep 10, 2006 07:27 PM
drSquish
Jan 19, 2006 01:54 PM
b16hatche
Oct 24, 2005 08:03 PM
sivik2nr
Jun 11, 2003 09:59 PM
