How much cash to fix "minor surface rust"??
Old May 12, 2005 | 01:21 PM
TenLarge's Avatar
Default How much cash to fix "minor surface rust"??
along the sheel wells or the bottom of the door....
what methods can i use/spend on
and whats the approximate price?
EDIT: im still a trial user so i cannot post more then 4 replies (5 with this one) so check my previous posts for a responce to your questions/comments
civiccpedx: it is only surface, but how do i paint it myself? i have to match the colors, sand down the entire fender/door pannel and find a spray gun and a spray booth?
Old May 12, 2005 | 01:24 PM
civiccpedx's Avatar
Default Re: How much cash to fix "minor surface rust"?? (TenLarge)
prolly 200-300 at a shop
if you do it yourself, all you really have to do is grind it down really good, assuming it is only surface, then bondo to fill the missing spot and paint
Old May 12, 2005 | 01:42 PM
TenLarge's Avatar
Default Re: How much cash to fix "minor surface rust"?? (civiccpedx)
anyone want to add to this?
Old May 12, 2005 | 01:57 PM
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">
if you do it yourself, all you really have to do is grind it down really good, assuming it is only surface, then bondo to fill the missing spot and paint </TD></TR></TABLE>
Thats what I did for mine. He hit it right on the money.
Old May 12, 2005 | 02:07 PM
TenLarge's Avatar
Default Re: How much cash to fix "minor surface rust"?? (mwieczorek43)
how timely will this process be?? and how much skill do u need? :S
Old May 12, 2005 | 04:50 PM
TenLarge's Avatar
bump
Old May 12, 2005 | 05:02 PM
NonovUrbizniz's Avatar
Loved
depends on how deep the rust goes, and How good you are at painting, Could take a couple of hours could take a LOT longer... and end up costing you even more when you give up and go to a shop.
Have you ever painted anything before?
Old May 12, 2005 | 06:28 PM
92civicb18b1's Avatar
Default Re: How much cash to fix "minor surface rust"?? (NonovUrbizniz)
Most paint shops will do a touch up for &gt;$100.
As for the rust. You said it was just surface, so like someone said, Grind it down/off. Bondo it up, you need to have some type of skill if it's a big area. You can't just slap a glob of bonda on and expect it to look good.
Actually it's more of the sanding part you need to know how to do, a regular sanding block is going to take longer but may yield better results. I can use an electric shaker sander and get it looking new.
Old May 12, 2005 | 06:29 PM
Turbo_y8's Avatar
Default Re: How much cash to fix "minor surface rust"?? (92civicb18b1)
buy a new car and photoshop
Old Apr 1, 2008 | 06:22 PM
TurbdEG6's Avatar
Default Re: How much cash to fix "minor surface rust"?? (Turbo_y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">buy a new car and photoshop </TD></TR></TABLE>
clone stamp ftw
Old Apr 1, 2008 | 06:29 PM
z6hatchboy's Avatar
you can do as mentioned with bondo, but if you have some friends or connections to help you can do as i recently did in my shop class. Had a 2" long piece of straight rust on the back quarter. I grinded it down, welded it up, bondoed, then touched it up. Not too hard if you some people to help. I think we charged around
$300.
ieatrice
Nov 7, 2005 11:21 PM
infinitetruth
11
Jun 24, 2004 02:50 AM
weakGOODJunKieS.com
Feb 25, 2004 07:39 PM
Heisdan
Jul 29, 2003 10:24 PM
weakGOODJunKieS.com
Jun 2, 2003 03:16 PM
