Oil Pan!!help asap!!!
Old May 12, 2005 | 11:34 AM
bjfisher's Avatar
Default Oil Pan!!help asap!!!
ok i need a new oil pan for my b16a.how do you change it?does the tranny have to be removed?ive never done this or anything so i need some help.im also assuming i should change the gasket.
also if anyone knows where i can get a cheap one really quick, please let me know....
Old May 12, 2005 | 02:13 PM
EG6 SiR's Avatar
Default Re: Oil Pan!!help asap!!! (bjfisher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher &raquo;</TD></TR><TR><TD CLASS="quote">ok i need a new oil pan for my b16a.how do you change it?does the tranny have to be removed?ive never done this or anything so i need some help.im also assuming i should change the gasket.
also if anyone knows where i can get a cheap one really quick, please let me know....</TD></TR></TABLE>
No, the tranny does not have to be removed. Its very simple. Here are the steps:
Tools Needed: 12mm socket, 10mm socket, 12mm wrench, torque wrench.
*Unplug O2 Sensor
*Unbolt Header/Exhaust Manifold
*Remove Flywheel dust cover
*Remove Oil pan
Dont forget to torque the oil pan down to specs. Make sure when you tighten the oil pan you start from the middle, then work your way out.
Old May 13, 2005 | 10:31 AM
JimBlake's Avatar
edit... ok I found this:
Gotta take off those braces from the block to the bellhousing, #13 & #14.
Day before you start, lay the oil pan gasket out flat, so it isn't trying to curl itself up while you install the new pan.
The old gasket might have steel rings around some of the bolt holes. Make sure you don't leave those behind, stuck to the bottom of the block.
Some people (me) use a tiny amount of sealant at the seams of the rear-main seal (#7) & the oilpump (not shown) at the front. Some people use it all around the gasket. Make sure you don't use too much, or it lubricates the gasket & makes it squirm around & leak.
Oil pan bolts take a pretty low torque (look it up?). If you overtighten them, the rubber gasket squirms around & leaks.
Modified by JimBlake at 2:43 PM 5/13/2005
Old May 13, 2005 | 11:43 AM
bjfisher's Avatar
thanks got it done, no biggy at all
btw, its 9lbs for torqing the bolts
jdmwojo
12
Feb 1, 2010 08:34 PM
wdissident
Jan 19, 2009 08:49 PM
BANting
Dec 21, 2004 08:26 PM
Si Shane
10
Dec 13, 2004 05:35 PM
Loveless
Apr 23, 2003 04:57 PM
