Ignition failed, then worked, now failed
Old May 12, 2005 | 11:16 AM
Joel2204's Avatar
Default Ignition failed, then worked, now failed
It started when I got off the interstate and got down to low rpms. It was hot and I had the a/c on. The car bogged, then completely shut off. Popping the clutch did nothing, and at first trying to start it produced a little rpm's, but not enough to make it run. After taking a look at it on the side of the road and trying to start it several times, it finally started after about 10 minutes. I drove it for another 4 minutes when it died again, and it hasnt started since. It's turning over and getting fuel, but it's not getting any spark. I checked all the fuses and jiggled all the connections in the bay.
I have a 93 del sol si. I just recently replaced the ignitor coil, and I have had a leaky injector that I think it stuck open.
Has anyone had any similar problems that can maybe lead me in the right direction to fix this problem? Any help is appreciated!
-Joel
Old May 12, 2005 | 01:09 PM
Supahr_Ed's Avatar
Default Re: Ignition failed, then worked, now failed (Joel2204)
you can always try the ignitor....i know it usually goes defective during hot days but then it usually works again after it cools down...
Old May 12, 2005 | 02:39 PM
Chiovnidca's Avatar
Have you checked the ignition coil?
Old May 14, 2005 | 11:35 PM
Supahr_Ed's Avatar
did you find our what happen????
Michael.K.Conte
May 29, 2010 12:01 PM
s2knjax
Feb 8, 2010 12:00 PM
jsharpe
Aug 6, 2007 01:15 PM
ricodemus
Mar 4, 2003 03:18 AM
