anybody polished/paint theres?
valve cover- ive posted this in a/c too but i havent seen many h22 ones
ok i stripped down my valve cover with aircraft remover. found quite a bit of diff grits at my house, 180/320/600/800/1000/1500 thinking about go out and buying 2000 grit (anyone have any pics of 2000grit polished?)
my question is what kind of polish is better, i saw a member on here using mothers mag&aluminum polish and other ppl saying to get a rubbing compound?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneThirtyEight »</TD></TR><TR><TD CLASS="quote">Start out coarse and move your way to finer and finer grits. Once you do not have "scratches" in it anymore you need to hit it up with an electric buffing wheel and some rouge if you want it a "mirror finish".
Alum polish is for after its done to clean it and remove oxidation with. A rubbing compound is simliar to rouge and would also probably work but a machine will polish it so much faster. </TD></TR></TABLE>
thanks man
but what is rouge? where can i buy it/how much? i know it will take long, but can i do the rouge and polish part by hand? i did some testing on a old valve cover with just sanding it and aluminum polish and it looks ok so far, but not the "mirror finish" i want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slipjack »</TD></TR><TR><TD CLASS="quote">1500 grit is probably enough. It'll be way smooth. As for the rest ^^^^^ -- ditto.
EDIT: Wet sand once you get to the finest grit.</TD></TR></TABLE>
oh i was told to wetsand every grit. is it where you dip the sand paper in the cup of water and soap and then sand for a bit, then dip again and sand again?
thanks man
but what is rouge? where can i buy it/how much? i know it will take long, but can i do the rouge and polish part by hand? i did some testing on a old valve cover with just sanding it and aluminum polish and it looks ok so far, but not the "mirror finish" i want<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slipjack »</TD></TR><TR><TD CLASS="quote">1500 grit is probably enough. It'll be way smooth. As for the rest ^^^^^ -- ditto.
From: united states of mexico and yes ladies i am, available
yeah just keep the sand paper wet and just do it till its smooth and if you wanna polish it i hear flitz is great and if you wanna paint it like jdm red use a wrinkle paint the more coats you use the more wrinkle it has
i painted mine silver. it was pained red before and i just got some of that paint remover...That was a pain getting the old paint off, but i just spray painted it silver and put it back on. Turned out pretty good. simple job.. As far as polising..a drimel tool is a must for getting in all the small nooks and crannys. You will only get the high shine with an electric or air controlled buffer
i dont think you need soap and water to wet sand it. I just got an old spray bottle and filled it with water and just spray to keep it wet.
in the first 5 seconds of searching look what i found.
https://honda-tech.com/zerothread?id=863008
The search button is there for a reason, give it a try. Also, that is a picture of a B-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 »</TD></TR><TR><TD CLASS="quote">
umm... thats a spoon valve cover. not homemade. and its also on a B18c1.
</TD></TR></TABLE>umm... thats a spoon valve cover. not homemade. and its also on a B18c1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 »</TD></TR><TR><TD CLASS="quote">is there a difference? did he just power coat it yellow?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude »</TD></TR><TR><TD CLASS="quote">its called powder coating</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude »</TD></TR><TR><TD CLASS="quote">he didnt do it..............Sp000n did</TD></TR></TABLE>
spoon powdercoats OEM Type R valve covers their specific yellow. to get a brand new OEM valve cover and get it powder coated any color would be about the same as the price of the spoon, so just get the spoon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude »</TD></TR><TR><TD CLASS="quote">i painted mine silver. it was pained red before and i just got some of that paint remover...That was a pain getting the old paint off, but i just spray painted it silver and put it back on. Turned out pretty good. simple job.. As far as polising..a drimel tool is a must for getting in all the small nooks and crannys. You will only get the high shine with an electric or air controlled buffer
to get all of the old paint off you just use aircraft stripper. spray it on very thick, leave for 30 minutes then spray it off with a hose. now its bare metal.
If you add soap to the water when you wetsand, it helps clean off the metal and better prepares it to accept new paint. If you plan to just polish it, the soap isn't needed.
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes »</TD></TR><TR><TD CLASS="quote">spoon powdercoats OEM Type R valve covers their specific yellow. to get a brand new OEM valve cover and get it powder coated any color would be about the same as the price of the spoon, so just get the spoon
where can you get one?
</TD></TR></TABLE>where can you get one?
where can you get one?</TD></TR></TABLE>
for the prelude? you cant. read again. spoon powdercoats oem TYPE R valve covers. you dont have a type R engine do you? or a B16? then it wont fit. JUN is the only one that loves the lude, and they dont do bling.
i kno this is kinda off subject in this post.. but in ur pic, i see that u dont have an "everyday" intake manifold.. what are they like velocity stacks for a 4cyl?? lol just interested in finding out cause it left me puzzled
actually i have seen the JUN color scheme on their race kaas but they dont sell them. Lime green in the front then fades to the famous super lemon ^_^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WtPanther »</TD></TR><TR><TD CLASS="quote">i kno this is kinda off subject in this post.. but in ur pic, i see that u dont have an "everyday" intake manifold.. what are they like velocity stacks for a 4cyl?? lol just interested in finding out cause it left me puzzled</TD></TR></TABLE>
it depends on the car, the ITB (individual throttle bodies), also what you are tuning with.
if they are a good ITB and a well built engine then you can make serious power. but they are not cheap by any means. those are toda ITB's. TWM makes them for the H22 but they run about 1300 bucks. then you need other things to make it work.
the TWM TB's are cheaper then Toda for b series ( irrelavent in the Prelude forum but o well) TWM is the only company i know of that makes them for the H series.
jdmstockeg6
22
Sep 9, 2007 07:27 AM
