does this sound like a good size for my motor?
Old May 12, 2005 | 08:00 AM
VtecAdil's Avatar
Default does this sound like a good size for my motor?
this is for a bone stock d16y8, its a garrett T3/To4e 60 trim, 60/48 a/r. does that sound like its overkill for my motor and will lag very badly?
Old May 12, 2005 | 08:03 AM
pv2dickman's Avatar
Default Re: does this sound like a good size for my motor? (VtecAdil)
yea.. you will have quite a bit of lag
past 5000 rpm im thinkin.. but lot of power
what is your hp goal
Old May 12, 2005 | 08:05 AM
VtecAdil's Avatar
right now it is around 210 whp. i dont plan on building the motor till much later, like wayyy later. my options are to send it back, and get a 57 trim, or a T3 42/48.
Old May 12, 2005 | 08:44 AM
VtecAdil's Avatar
bump for an answer
Old May 12, 2005 | 08:50 AM
TurboGoKart's Avatar
Default Re: (VtecAdil)
If you're only looking for about 210 whp, I would definately go with a T3. Either .60 trim, or something of the like. You'll have really good spool times, and that turbo will easily get you to your goal. I will be running a T3/T04E .60 trim, .63 a/r, stage 3 wheel on my new setup, but I am also looking for 350whp. Definately trade that turbo in for a T3 given your power goals.
Old May 12, 2005 | 09:31 AM
hatchinprogress's Avatar
Default Re: (TurboGoKart)
you will have crazy lag
Old May 12, 2005 | 09:39 AM
Default Re: (hatchinprogress)
If you're talking about me and my T3/T04E, it wont be as much as you think. Gitwidit on here has an SC61 on his D16Z6, and it's really not that laggy. I've driven his car before. Not as bad as you think. And the SC61 is bigger than mine.
But if you were saying you'll have terrible lag with the T3, I disagree.
Old May 12, 2005 | 12:17 PM
nerdsports's Avatar
was looking to get a .48exh/.60comp t3 for my d16 but wanted to hear from a few people before hand...
what other turbo can i get that is slightly smaller??
Old May 12, 2005 | 02:14 PM
Default Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">was looking to get a .48exh/.60comp t3 for my d16 but wanted to hear from a few people before hand...
what other turbo can i get that is slightly smaller?? </TD></TR></TABLE>
That one is fine. I have that one currently on my car. slightly bigger exhaust though, but that is a great turbo for a D16. You could always get a GT28r or rs, but you'll spend a fortune on that one. It'll spool up ridicuously fast and also be able to make a bit of power. A T3 is a good choice for a D series though.
Old May 12, 2005 | 06:45 PM
grndcont's Avatar
i have that same to4e 60 on my built 18c1, and it's laggy on that motor! i would deffinetly sugjest a smaller unit for your aplication. unless of course you want to by it from me so i can buy a 57 trim. I just purchesed a t3 super 60 for my stock 1.8l miata and am having second thoughts about i being too small. meby you could try someting in the middle like a 54. try this web calculator and see if if helps. http://www.not2fast.com/turbo/...shtml
Old May 12, 2005 | 07:19 PM
Muckman's Avatar
Moderator in Chief
thats way too big for a stock d. it'll pop before you even get into the efficiency range of that turbo. haha
almostboostedgsr
Apr 9, 2007 08:18 PM
carlos11
Mar 18, 2005 07:13 PM
SPOON_BeIgHtEeNsEe
Apr 29, 2004 11:55 AM
TurboCX
Apr 9, 2003 02:17 PM
