Could I install my G Blubox today even thought my kit won't install for 2 days?
I am working on a small time period this weekend when my kit arrives, and I am off today so I figured I could go ahead and install my blue box to save time this weekend by allready having this done, would the car be driveable, and would I need to go ahead and put in the 310 injectors as well?
wrong and yes.
You'll run way rich and lose power vs stock. It will add fule the WHOLE time, anytime you touch the gas buebox is adding fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">wrong and yes.
You'll run way rich and lose power vs stock. It will add fule the WHOLE time, anytime you touch the gas buebox is adding fuel.</TD></TR></TABLE>
Really? I don't know much about the blue box but I would think he would be okay installing it...
You could do it with any other fuel management setup, why couldn't you do it with the blue box?
I think I am going to go ahead and install but what about the injectors?
the blue box only increases fuel pressure when there is boost..
you wont be boosting so you wont have a problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pv2dickman »</TD></TR><TR><TD CLASS="quote">the blue box only increases fuel pressure when there is boost..
Wrong, it modifies the injector pulse, not bumps up fuel pressure...Anyway, YES, I know for a fact you can install it before the turbo kit...I have a blue box on my car now, and under approx. 20-30% throttle, my wideband stays around 14.-0-14.6, so if you drive it sensibly, it will not affect anything at all..
it doesn't add fuel in vacuum, cuz that doesn't make sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr »</TD></TR><TR><TD CLASS="quote">
yes.. i was thinking something totally different..
</TD></TR></TABLE>yes.. i was thinking something totally different..
well I drove the car for about an hour to go eat and some other stuff and car seem to run better. Seem to be a little smoother on power delievery. Could it be the injectors being bigger?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bimmerman »</TD></TR><TR><TD CLASS="quote">well I drove the car for about an hour to go eat and some other stuff and car seem to run better. Seem to be a little smoother on power delievery. Could it be the injectors being bigger?</TD></TR></TABLE>
it could be due to the change from old dirty clogged injectors to brand new clean ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
it could be due to the change from old dirty clogged injectors to brand new clean ones?</TD></TR></TABLE>
Or a placebo effect is kick'n in
haha
Anyways enjoy the MaD thrID GeAr Vt3c B0osT when you get it installed
hahaAnyways enjoy the MaD thrID GeAr Vt3c B0osT when you get it installed
it doesn't add fuel in vacuum, cuz that doesn't make sense</TD></TR></TABLE>
Thanks, but no one like bad information. I drove a blue boxed car around for almost 6 months with zeitronix unit afr/boost lcd display. By 14in its on its way to 10.
fuzzysig
Jun 1, 2017 06:42 PM
jdm98ex
35
Apr 2, 2003 10:48 PM
