someone tell me how to bench bleed
Old May 11, 2005 | 09:52 PM
Leb_CRX's Avatar
Default someone tell me how to bench bleed
before I unleash my kung-fu up in here
Old May 11, 2005 | 10:05 PM
nocturnaldragon's Avatar
Default Re: someone tell me how to bench bleed (Leb_CRX)
What are you bleeding?
Im going to assume a master cylinder. If so hook hoses up to the ports where your steal lines would normally go into then loop them back into your reservoir, Now fill up the reservoir with fluid. pump it up until no more bubbles come out.
Old May 12, 2005 | 05:37 AM
Leb_CRX's Avatar
Default Re: someone tell me how to bench bleed (nocturnaldragon)
yep master cylinder
sweet, sounds easy enough
Old May 12, 2005 | 05:52 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leb_CRX &raquo;</TD></TR><TR><TD CLASS="quote">yep master cylinder
sweet, sounds easy enough </TD></TR></TABLE>
I hate to rain on the parade, but you're supposed to bench bleed any kind of cylinder before you hook it up to the car. Most MCs come with plugs to put in the brakeline-out ports that you use.
When I do musclecars, this is what I do:
1.) use supplied plugs to seal off the brakeline-out holes.
2.) fill reservoir with brake fluid.
3.) using the handle of a screwdriver (or something equally solid), actuate the piston several times until you get some real resistance. It might be easier to get a friend to hold the cylinder while you pump.
4.) install.
Old May 12, 2005 | 06:11 AM
North_Texas's Avatar
Default Re: someone tell me how to bench bleed (Archidictus)
A friend is always better to help with. If you can't located a friend and spend some $. You can go to Autozone where they have a bleeder kit.
Old May 12, 2005 | 06:25 AM
Leb_CRX's Avatar
you are not raining on my parade dude, I asked because I want to do it
thanks for the help
djkurious
May 19, 2009 04:22 PM
Jay Dirt
Oct 26, 2007 05:27 PM
yz125rider21
20
Mar 4, 2007 12:58 PM
integracura
Sep 28, 2006 06:21 PM
dc4pos
Sep 13, 2006 05:09 PM
