CV Boot torn. New Axle? (Autozone?)
Old May 11, 2005 | 08:22 PM
p nut's Avatar
Default CV Boot torn. New Axle? (Autozone?)
My CV boot is a goner, so I'm looking to replace the whole axle.
How many of you guys have Autozone axles? I've heard they're good (lifetime warranty) but they break a lot. Just wondering what your experiences are with them or if there are better alternatives. Thanks.
Old May 11, 2005 | 08:25 PM
Opie's Avatar
<--Auto Zone axled. Lifetime warranty =
Old May 11, 2005 | 08:29 PM
Bbasso's Avatar
Default Re: CV Boot torn. New Axle? (P Nut)
https://honda-tech.com/zerothread?id=1117962
Old May 11, 2005 | 08:30 PM
cxSHOE's Avatar
just changed my boot. $12.00 bucks. i would check the axle to see if you have lots of dirty.. if not just change the boot.. autozone was the only place around me that had the split type boot... comes with enough grease too.
Old May 11, 2005 | 08:41 PM
p nut's Avatar
Thanks for the link, Bbasso. raxles.com seems like a good place, but NAPA might be quicker.
cxSHOE - 95% of the people that have used the split type boot said that it gave out in a couple of months. I'd rather change out the axle and get it over with. Thanks for the input, though.
Old May 11, 2005 | 08:44 PM
cxSHOE's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the link, Bbasso. raxles.com seems like a good place, but NAPA might be quicker.
cxSHOE - 95% of the people that have used the split type boot said that it gave out in a couple of months. I'd rather change out the axle and get it over with. Thanks for the input, though.</TD></TR></TABLE>
yea... ill see what happens in the next couple of months.. im lowered 3" too which probably doesnt help i may be be going the axle root too... hopefully not.
Old May 11, 2005 | 09:42 PM
Arsenal's Avatar
Default Re: (cxSHOE)
Split boots are crap. End of story, its a R, give it some respect.
Old May 12, 2005 | 01:47 PM
01usjdmr's Avatar
Cheap axles suck, get gator axles. Most upgraded companies will help you out if you break them.
Old May 12, 2005 | 01:57 PM
len's Avatar
len
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">&lt;--Auto Zone axled. Lifetime warranty = </TD></TR></TABLE>
Why not? That's what I would do. Or Gator Racing Axles.
Old May 12, 2005 | 02:06 PM
p nut's Avatar
Default Re: (len)
Even though they're lifetime warranteed, others have had to changed them out constantly (i.e. every 1-3 months). That's not really worth it for me. I have heard good things about GCK's (which are brand new axles from Autozone). They're a little more expensive, but better quality than remanufactored ones. Also carries a lifetime warrantee. I'll pick some of these up Sat.
Old May 12, 2005 | 03:05 PM
bitzbp's Avatar
Default Re: (P Nut)
I would just buy the Autozone axles. I have seen them last a long time, but occasionally they go bad quickly, but thats usually on cars that are severely lowered and get launched a lot. Besides once you have done axles a few times its an easy job. I can usually swap both axles in 20 min or so. Plus you can't beat the lifetime warranty
Old May 12, 2005 | 03:18 PM
HondaRcB's Avatar
Default Re: (bitzbp)
I went through 3 axles from Advanced Auto in about 300 miles. They sucked. The only had the remans in my neck of the woods, not the new ones. I 'm running some used ITR axles now with no problems.
Old May 12, 2005 | 05:29 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: (HondaRcB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaRcB &raquo;</TD></TR><TR><TD CLASS="quote">I went through 3 axles from Advanced Auto in about 300 miles. They sucked. The only had the remans in my neck of the woods, not the new ones. I 'm running some used ITR axles now with no problems. </TD></TR></TABLE>in my crx, i recently broke one of my gators, which i didnt have a reciept for, so i bought some advance auto **** axles. EVERY time i shift hard from 1-2 now, they blow apart the joints. at least they warranty them. Dont be a cheapass like me, get good ****.
Old May 12, 2005 | 05:33 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">How many of you guys have Autozone axles?</TD></TR></TABLE>
Do yourself a favor -- stay far, far away from them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">I've heard they're good (lifetime warranty) but they break a lot.</TD></TR></TABLE>
Oxymoron?
My suggestion would be a new (not remanufactured) axle from Napa. Should run approx. $150.00, and comes with a lifetime warranty.
sohcef9
15
Oct 2, 2005 06:39 AM
athoughts
16
Sep 27, 2005 12:49 PM
Keewun
Dec 20, 2004 04:21 AM
sinfulDB1
Dec 2, 2003 10:53 AM
davidbui
Jan 13, 2002 04:17 AM
