Misfiring/bogging while building boost
Old May 11, 2005 | 08:21 PM
EGkid's Avatar
Default Misfiring/bogging while building boost
Alright here's my problem, im at low rpm, then i start to build boost, then around 5-6 K i begin to bog somewhat, boost doesn't feel as smooth when it starts to spool up, almost like its hesitating.
Although currently i have high fuel pressure it shouldn't affect my performance to that extent. I checked cylinder #1 spark plug and it seemed fine, i will still most likely replace them. I also had the ignitor replaced in the distributor before the car was even tuned.
So i'm wondering what other issues may be causing this problem, i will check tomorrow once i get my plugs to see if it keeps occuring, but i'm wondering for future references what else it may be. Also the wires are new too so i highly doubt its them.
thanks
Old May 11, 2005 | 08:28 PM
Slammd Sol's Avatar
Post your full setup, especially your fuel managment. Im hoping you have one of those..
Old May 11, 2005 | 08:32 PM
EGkid's Avatar
Default Re: (Slammd Sol)
b18c longblock
.5 over
cp pistons/eagle rods
sc61 to4s cover
720 rc's
uberdata
inline pro mani
38mm tial wg
Old May 11, 2005 | 08:33 PM
Slammd Sol's Avatar
Sounds like a fuel or ignition problem to me. Get a wideband on it and report back with some AFR #'s.
Old May 11, 2005 | 08:38 PM
EGkid's Avatar
car was just freshly tuned about a week and a half ago, if anything i'm thinking my current fuel problem that i have may be the issue but to cause the turbo to hesitate alittle i can't really see that
Old May 11, 2005 | 09:37 PM
FredoSP's Avatar
what heat range are your plugs?
Old May 11, 2005 | 10:55 PM
EGkid's Avatar
Default Re: (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">what heat range are your plugs?</TD></TR></TABLE>
not 100% positive, but i know they are the NGK BCPR7E's and i have them gapped around 28-29
Old May 11, 2005 | 11:58 PM
leed's Avatar
Default Re: (EGkid)
Is this happening right after cross-over? If so, are you on ITR's?
Post a screen shot of the appropriate fuel map in 2d.
Old May 12, 2005 | 07:19 AM
EGkid's Avatar
Default Re: (leed)
no its happening before cross over and yes i'm on itr's
Old May 12, 2005 | 07:26 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
i think it's a tune. you might want to clean up your map a little more.
Old May 12, 2005 | 08:44 AM
EGkid's Avatar
Default Re: (h22boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy &raquo;</TD></TR><TR><TD CLASS="quote">i think it's a tune. you might want to clean up your map a little more.</TD></TR></TABLE>
it was running PERFECT when i got it back, right now i believe i'm running 65+psi fuel pressure at idle (not too sure cause my gauge broke and the liquid filled is comming in tomorrow)
Old May 12, 2005 | 08:45 AM
EGkid's Avatar
Default Re: (EGkid)
here's a graph of my tune
Old May 12, 2005 | 09:04 AM
ILLA_00LS's Avatar
Default Re: (EGkid)
to me it sounds like fule problems.. when i was running around on an open FMU w/ no FULE contorler.. and 440's as soon as i would spool the car would BUCK/Hesitate.. like a bastard.. .. ya i was flooding it.. yup i'm a dummy i know.. new block is on its way.. anyway.. i ended up cracking all 4 pistons.. and scuffing 3 cyilder walls.. check your fule... and ing...
LST2
Jul 10, 2007 06:15 PM
egvtec
Dec 23, 2004 11:53 PM
Integspeed21
Oct 3, 2004 12:48 AM
shermanyang
Aug 6, 2004 10:28 AM
