Std vs auto.. can ECU be used in either?
Old May 11, 2005 | 05:29 PM
Jan in Omaha's Avatar
Default Std vs auto.. can ECU be used in either?
I am in need of a new ECU for my 92 Civic Si (manual) I believe I need a P28 ECU. Can I use any P28 ECU from 92-95 Si/EX even if it's from an automatic car?
Sorry for the question... but I didn't find it in the search.
(cross posted in tech forum)
Old May 11, 2005 | 05:31 PM
Bcuz's Avatar
Default Re: Std vs auto.. can ECU be used in either? (Jan in Omaha)
No the auto comp. will not work.
Old May 11, 2005 | 05:33 PM
Default Re: Std vs auto.. can ECU be used in either? (Bcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz &raquo;</TD></TR><TR><TD CLASS="quote">No the auto comp. will not work.</TD></TR></TABLE>
Is there a code on the computer that will tell me what if it's for an auto or a manual tranny?
Old May 11, 2005 | 08:03 PM
alleyezonme's Avatar
should be something on the comp. #'s. my friend got an auto ecu with his manual swap and couldn't rev as high!
Old May 12, 2005 | 10:08 AM
Default Re: Std vs auto.. can ECU be used in either? (alleyezonme)
That's what I am wondering... is there a certain code printed on the outside of the computer that will tell if it's an auto or manual?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme &raquo;</TD></TR><TR><TD CLASS="quote">should be something on the comp. #'s. my friend got an auto ecu with his manual swap and couldn't rev as high!</TD></TR></TABLE>
Old May 12, 2005 | 10:18 AM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jan in Omaha &raquo;</TD></TR><TR><TD CLASS="quote">That's what I am wondering... is there a certain code printed on the outside of the computer that will tell if it's an auto or manual?</TD></TR></TABLE>
Scroll down a little and it will tell you.
https://honda-tech.com/zerothread?id=810101
Old May 12, 2005 | 10:19 AM
IHateJDM's Avatar
It will work to get you from point a to point b. Usually there is a MT or AT on one of the labels. Check out pgmfi.org. That site will show you how to look at the board and tell, and also how to convert it if you can solder. If you can't solder, I'm sure someone on the board will convert it for you for the right price.
Old May 12, 2005 | 10:24 AM
JDM-EJ1's Avatar
Default Re: Std vs auto.. can ECU be used in either? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">It will work to get you from point a to point b. </TD></TR></TABLE>
Yeah don't do that.
Old May 12, 2005 | 10:51 AM
IHateJDM's Avatar
Default Re: Std vs auto.. can ECU be used in either? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah don't do that. </TD></TR></TABLE>
It will work, and it will not have any adverse effects on your car.
Old May 12, 2005 | 10:59 AM
Default Re: Std vs auto.. can ECU be used in either? (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=810101</TD></TR></TABLE>
Excellent!!
Old May 12, 2005 | 04:43 PM
mtber's Avatar
Obd1 auto ecus can be converted to manual :-)
https://honda-tech.com/zerothread?id=1242980
lv6l
10
Dec 10, 2005 10:09 PM
tuoniz
Oct 28, 2005 01:22 PM
gt3hurman
Apr 20, 2005 10:50 AM
quicksol95
16
Mar 13, 2004 01:20 PM
CivicHB91
Dec 10, 2002 06:43 PM
