headlights dimming at higher RPM?
Old May 11, 2005 | 05:26 PM
RTW DC2R's Avatar
Default headlights dimming at higher RPM?
Well I recently noticed my headlights dimming when tapping the brakes. Actually its more of a flicker then back to normal. Then tonight I noticed at higher RPM my headlights would get really dim around 7K RPM all the way to redline. I only noticed it at WOT. Is this a sign of a bad alternator? I never have any starting problems and my battery is fairly new.
Old May 11, 2005 | 05:28 PM
Bbasso's Avatar
Default Re: headlights dimming at higher RPM? (RTW)
Get the volt meter out and see what the alt's output is.
Sounds like it's going bad.
1GreyTeg's Avatar
rodney musta done it with the hamma
Old May 11, 2005 | 08:16 PM
KayOs's Avatar
brake booster going bad?
faulty ground somewhere?
alternator going bad ?
Modified by KayOs at 12:28 AM 5/12/2005
migs's Avatar
Default Re: headlights dimming at higher RPM? (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">brake booster going bad?</TD></TR></TABLE>
Old May 11, 2005 | 08:17 PM
Opie's Avatar
My guess is the alternator is taking a **** on you. Check the ground.
Old May 12, 2005 | 05:23 AM
JOHN WAYNE's Avatar
Default Re: (opie)
this is sort of similar to a common problem with 96-00 Civics when they have a b-series swap...i'm not sure if they are related or not.
the lights will dim and get brighter with changes in engine speed.
the quick and dirty solution (possibly the only one) is to de-pin the ALT-C wire from the ecu. from what i've heard, the ALT-C is just for purposes of fuel economy and basically controls when the alternator is actually going to be charging...hence the change in voltage that you can visibly see. by de-pinning it, the alternator will always be charging.
you can try de-pinning it...couldnt hurt. i had this problem with my civic and its been fine ever since i de-pinned the wire...no noticeable impact on fuel economy either.
Old May 12, 2005 | 05:28 AM
ebelp's Avatar
Default Re: (JOHN WAYNE)
Ryan, do you have HID's or halogens?
Old May 12, 2005 | 05:32 AM
m R g S r's Avatar
Default Re: (ebelp)
yea just get some HID's, it will fix the problem.. Most ballasts only need 8or9volts to remain operating.....And besides, oem halogens suckkkkk.
Old May 12, 2005 | 06:40 AM
BlackTOY's Avatar
My dash lights are currently doing the same thing. I only noticed it when i changed from my chipped ECU to my stock P72 so I am thinking that my battery or alternator is going south or its related to the ECU. Im not sure yet though.
Old May 12, 2005 | 07:01 AM
splitime's Avatar
Default Re: (BlackTOY)
Holy crap guys... you missed the obvious one! He is going so fast at WOT that he's beating the light from his headlights down the road!
m4d 3rd g34r vt4k
Old May 12, 2005 | 07:11 AM
Chris F's Avatar
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Holy crap guys... you missed the obvious one! He is going so fast at WOT that he's beating the light from his headlights down the road!
m4d 3rd g34r vt4k </TD></TR></TABLE>
Sweet, physics to the rescue! (Edit: Maybe he's just catching up to the electrons travelling in his headlight wires)
Sounds like he has a slightly weak battery to me. The high RPM signal thing (ALT-C) as well as the lights dimming slightly when the additional load of the brake lights hits for a moment.
RTW--
If I were you, I would totally ignore both issues. I have pretty much always seen the headlights dim just a little when touching the brakes, that's normal IMO.
A super-titanium-magnesium purple-top $150 uber battery would probably fix it.
-Chris
Old May 12, 2005 | 07:25 AM
RTW DC2R's Avatar
LOL@ catching up to the electrons
I dont think switching to HIDs is gonna fix the problem Evan lol
what is the voltage supposed to be at idle, around 13-14? how much fluctuation is there when in higher RPM or should the alternator keep it pretty constant? Im gonna check it just to be safe.
Old May 12, 2005 | 08:41 AM
Bbasso's Avatar
Default Re: (RTW)
Anything less then 13 in NG.
But if you got 13+ then it's your battery.
95streetciv
Mar 31, 2009 11:29 AM
b00sted4dr
May 30, 2005 09:53 PM
DVS Luder
Jan 24, 2005 11:24 PM
loopid
Dec 28, 2003 10:45 PM
gofastgsr
Dec 4, 2003 04:47 AM
