Headlights Dim While Driving
Old Dec 2, 2003 | 03:22 PM
gofastgsr's Avatar
Default Headlights Dim While Driving
I have a 99 GSR and the headlights dim when I put on the brakes, cooling fan turns on and just while driving. It does happen more often when I slow down and then brightens when I speed up. It has happened for a little while, but has gotten much worse after I had my clutch replaced.
I have checked the ground wires (for the headlights), I have a new battery and the alternator is putting out 75 amps.
Any suggestions will be very appreciated...
Old Dec 2, 2003 | 03:37 PM
The HamsterBall's Avatar
Default Re: Headlights Dim While Driving (gofastgsr)
lol that sucks..
my camry kinda does something like that
when i'm driving, and i roll the windows up or down, the headlights dim..
SOMEBODY HELP THIS MAN!
Old Dec 2, 2003 | 03:39 PM
integraL's Avatar
Default Re: Headlights Dim While Driving (HamsterBall)
yep...this only happens when i'm idle though...its always been like that. maybe weak battery?
Old Dec 2, 2003 | 03:42 PM
tachyteg's Avatar
Default Re: Headlights Dim While Driving (integraL)
my car does the exact same thing...don't know why. I took it to the dealership, they replaced teh battery, and it still does it. When i'm at idle to windows go up slow, but if i rev it they go up quicker..haha
Old Dec 2, 2003 | 03:44 PM
4DooRGiSzer's Avatar
Default Re: Headlights Dim While Driving (tachyteg)
well, the same thing happened to my hummer, i just replaced the compressor which inflates the tires. and now my a/c is cold again! that fixed most of the rough idle surging problems.
Old Dec 2, 2003 | 05:16 PM
gofastgsr's Avatar
Any thoughts were I can start to look to identify the problem??????
Old Dec 2, 2003 | 05:22 PM
tC_Dragon's Avatar
Default Re: Headlights Dim While Driving (4DooRGiSzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DooRGiSzer &raquo;</TD></TR><TR><TD CLASS="quote">well, the same thing happened to my hummer, i just replaced the compressor which inflates the tires. and now my a/c is cold again! that fixed most of the rough idle surging problems. </TD></TR></TABLE>
hahahah.... how does that relate at all to the integra?? hahahahah.... how funny.
Old Dec 2, 2003 | 07:28 PM
[ iLL ] iNt3GrA's Avatar
my 99 gsr does it to when i speed up they get bright when i slow down they get dim i was thinkin could be the alternator
Old Dec 2, 2003 | 07:34 PM
Xymox's Avatar
Default Re: ([ iLL ] iNt3GrA)
Mine do it too. But only when I first engage the turn signals. I thought it had something to do with my OEM fogs.
Old Dec 3, 2003 | 05:17 AM
Default Re: (Xymox)
how about.. we all get HID's and the lights won't ever be dim.
Old Dec 3, 2003 | 05:57 AM
MrBite's Avatar
Check ALL your ground wires--and not just that they are there, but that they are clean (no corrosion) and tightly connected. If they're dirty just unbolt them, clean them off with a wire brush or something, and put them back. It also couldn't hurt to upgrade the factory grounds, since they're really wimpy.
Old Dec 3, 2003 | 08:41 AM
Devlins 91LS's Avatar
Default Re: Headlights Dim While Driving (MrBite)
Its the alternator. All cars do it.
Unless its REAL bad, like to the point where if you step on the brakes at idle it stalls, i really don't see the problem.
Old Dec 3, 2003 | 09:43 AM
tC_Dragon's Avatar
Default Re: Headlights Dim While Driving (Devlins 91LS)
yea... i'm under the impressionthat its the alternator as well... especially more so on my car becuase i havent changed it ever and for the last oh 70k miles i've been bumpin my system like crazy so the drain on it is kinda big. I think i may need to get a cap.
Old Dec 3, 2003 | 01:19 PM
integra-modder's Avatar
Default Re: Headlights Dim While Driving (pdcdragon)
my HIDs dont dim
It could be result of a bad alretnator, but since your car is relatively new, I doubt it. Its probably a bad ground somewhere off of the engine.
Old Dec 3, 2003 | 05:06 PM
gofastgsr's Avatar
Sounds like I'm going to check all my grounds, upgrade the battery and engine grounds. If I still have a problem, I'll have to live with it.
Thanks for all the input.
Old Dec 3, 2003 | 05:53 PM
1998_4dr_gsr's Avatar
no need to check all your grounds...its just the way it is...when headlights are on...engine is spinning slower generating less power and therefore the alternator will be under some stress therefore causing power supply to go lower (like windows going down slower, or headlights dim while at idle.) Its like tryin to roll all your windows down at once...it's slower because it requires more power to do these things at the same time. But if the engine is revving high, the belts spin the altnerator causing more power to meet the power demands. Hope this helps and make a lil bit of sense
*thumbs up*
Old Dec 3, 2003 | 05:57 PM
DC4 teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamsterBall &raquo;</TD></TR><TR><TD CLASS="quote">lol that sucks..
SOMEBODY HELP THIS MAN!</TD></TR></TABLE>
my old 96 camry used to do the same thing!!!!!!! GO CAMRY!
Old Dec 3, 2003 | 10:25 PM
put my HID's in today no more problem
Old Dec 3, 2003 | 10:30 PM
integraL's Avatar
when im at idle...and i turn the steering wheel...you can see the rpms go down a little, then go back up...or when i turn my a/c on...the rpms go down then back up....only WHEN IM IDLE! anyone know? is it the alternator?
Old Dec 3, 2003 | 10:46 PM
refer to my post.....absolutely normal..GEEZ
Old Dec 4, 2003 | 04:47 AM
MrBite's Avatar
Default Re: (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">when im at idle...and i turn the steering wheel...you can see the rpms go down a little, then go back up...or when i turn my a/c on...the rpms go down then back up....only WHEN IM IDLE! anyone know? is it the alternator?</TD></TR></TABLE>
Well that is all normal. Everything electrical is run off the alternator, which is run off the engine. Put a load on the alternator and you put a load on the engine, which will bring the RPMs down a little. If the RPMs are low to begin with (at idle), this means the alternator will not generate full voltage and your lights will dim, etc. Now if it happens while you're driving, at higher RPMs (which I thought the original post was implying), you may have a problem.
itslogz
May 11, 2009 01:10 AM
DVS Luder
Jan 24, 2005 11:24 PM
F120man
15
Dec 22, 2003 06:57 AM
Quick Silver
Jun 25, 2003 07:06 AM
AGPSuperstar
Feb 7, 2003 10:17 AM
