custom fitting a lip onto my car.
Old May 11, 2005 | 04:23 PM
japmarket1's Avatar
Default custom fitting a lip onto my car.
hi i have this front spoon lip made of abs plastic. it is made for a 1998 accord but my car is a 1993 prelude. it somewhat fits although it is too long and doesnt hug the sides of the front bumper(sticks out on sides) how can this be fixed? what to use?
Old May 11, 2005 | 05:19 PM
surrealcivic17's Avatar
Default Re: custom fitting a lip onto my car. (japmarket1)
- I have an answer
my friend bought an abs plastic lip designed for a 99 civic and put it on his 92 hatch. What he did is where parts stuck out from the bumper, he added 3-5 washers where the screws where and that pulled the lip snug real good. And, u cant see the washers becuase they are up under the lip where the screws are. Lemme know if this makes sense and works
Old May 11, 2005 | 08:03 PM
japmarket1's Avatar
Default Re: custom fitting a lip onto my car. (surrealcivic17)
it does make sense and it doesnt. so he just used washers then? how does it look now? cant u still tell that it sticks out? im not a very hands on guy but is abs flexible like that?
Old May 11, 2005 | 08:05 PM
japmarket1's Avatar
the lip im talking about it sticks out almost and a bit more then 1 inch
Old May 12, 2005 | 09:31 AM
yeah definetly abs will pull snug right to the bumper, for a one inch gap id start with about 5 washers and then add one on or two on till it fits perfect.
Old May 12, 2005 | 09:34 AM
blackwagon's Avatar
why not just use a heat gun?
Old May 12, 2005 | 11:13 AM
riceisnicenv's Avatar
Default Re: custom fitting a lip onto my car. (blackwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackwagon &raquo;</TD></TR><TR><TD CLASS="quote">why not just use a heat gun?</TD></TR></TABLE>
this should work better and that is what should have been done on the other lip surreal mentioned. (i should have thought of that when installing phil's lip!!) BTW the 99 lip looks fine on the EG...
Old May 12, 2005 | 12:40 PM
japmarket1's Avatar
Default Re: custom fitting a lip onto my car. (riceisnicenv)
by using a heat gun i can get the plastic to form to the bumper right? or is there more to it then that? thanks !!
Old May 12, 2005 | 07:09 PM
if the curves are way off you can use a cutting wheel to cut pie shapes out of the inside of the lip (the bottom part) to make it bend easier
rick1574
Honda Civic (2001 - 2005)
Jun 14, 2007 01:40 PM
BB6-213
Honda S2000
Apr 20, 2006 09:04 PM
nighthawkgsr
Aug 7, 2005 11:17 AM
EJ1_519
Mar 14, 2004 05:37 PM
weakGOODJunKieS.com
Dec 13, 2003 12:50 AM
