When i buy an h22a will i have to...
Old May 11, 2005 | 02:04 PM
BenJammin's Avatar
Default When i buy an h22a will i have to...
I'm planning on buying a greddy evo 2 exhaust for my 94 prelude s this month. Later this summer I'm buying an h22a and i was wondering if the exhaust will fit up to the h22.
P.S. I searched but couldn't find.
Old May 12, 2005 | 07:31 PM
BenJammin's Avatar
Default Re: When i buy an h22a will i have to... (BenJammin)
cool. thanks for the help
Old May 12, 2005 | 07:36 PM
SilverPanda's Avatar
it should still fit. someone correct me if i am wrong
Old May 12, 2005 | 07:38 PM
monalisa overdrive's Avatar
Default Re: When i buy an h22a will i have to... (vtech22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 &raquo;</TD></TR><TR><TD CLASS="quote">it should still fit. someone correct me if i am wrong</TD></TR></TABLE>
you are wrong. vtec isn't spelled with an h.
Old May 12, 2005 | 07:44 PM
bby6's Avatar
I <3 Rotas
Default Re: When i buy an h22a will i have to... (monalisa overdrive)
wow, you are a hater. it's vtec/h22. DUHHHHHHH.
anyway, i think since it's not an SH it will fit. i'm not sure though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monalisa overdrive &raquo;</TD></TR><TR><TD CLASS="quote">you are wrong. vtec isn't spelled with an h.</TD></TR></TABLE>
OMFG for like the 1 millionth time it is vtec H22 hello pay attention.
Old May 12, 2005 | 07:51 PM
The Phil's Avatar
For probably the thousandth time i've said for this guy...its ******* VTEC H22. vtec h22 makes a lot more sense than vtech 22.
People just love that stupid phone picture.
Old May 12, 2005 | 08:08 PM
specialedition's Avatar
Default Re: When i buy an h22a will i have to... (xthephilx)
and I just love your posts.... x you must be going for the largest amount of posts in the shortest time on honda tech award...
aftermarket exhausts are the same from the cat back it is the header that is different on h23a cars vs. h22as this can be corrected by enlongating the holes on the flex pipe...
Old May 13, 2005 | 10:48 AM
BenJammin's Avatar
Default Re: When i buy an h22a will i have to... (specialedition)
so it will fit fine im kind of new at this and i don't really understand what your trying to say b/c i don't have an h23 i have an f22a and i want to drop an h22 in it.
Old May 13, 2005 | 01:51 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenJammin &raquo;</TD></TR><TR><TD CLASS="quote">so it will fit fine im kind of new at this and i don't really understand what your trying to say b/c i don't have an h23 i have an f22a and i want to drop an h22 in it.</TD></TR></TABLE>
No, it won't work.
Old May 13, 2005 | 01:54 PM
IHateJDM's Avatar
Default Re: When i buy an h22a will i have to... (maxvtec7500)
take it to an exhaust shop, and they will make it work.
Old May 13, 2005 | 03:09 PM
Freddiesluda's Avatar
Default Re: When i buy an h22a will i have to... (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">take it to an exhaust shop, and they will make it work. </TD></TR></TABLE>
Thats what i had to do.... it was to long by like 8 inches if i recall correctly
Old May 13, 2005 | 07:52 PM
BenJammin's Avatar
So basically if i put the h22a in first and then get an exhuast thats for the 5th gen vtec prelude, if its from the engine is from the 5th gen than it should fit.?
Old May 13, 2005 | 10:15 PM
Sabbotage's Avatar
when i swapped my H22 into my 92 Si i ordered my exhaust for a 4th gen VTEC prelude and it bolted right up. I'm pretty sure a 5th gen exhaust is different so it would require some modification. I would just wait until you do the swap and put the exhaust on then.....
Old May 16, 2005 | 06:10 AM
IHateJDM's Avatar
Default Re: When i buy an h22a will i have to... (Sabbotage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenJammin &raquo;</TD></TR><TR><TD CLASS="quote">So basically if i put the h22a in first and then get an exhuast thats for the 5th gen vtec prelude, if its from the engine is from the 5th gen than it should fit.?</TD></TR></TABLE>
buy the exhaust for the car, not the motor. just determine the diameter of the exhaust by the motor. try kteller.com. you can piece together your own exhaust. That's what I did my my h.
boostedNOTHARDLY
Sep 26, 2017 05:16 AM
jdm_jeners
Dec 4, 2006 04:32 PM
cpforyou
Feb 28, 2005 12:30 PM
sleepinbeauTEG
May 25, 2004 12:11 PM
DrunkNRacer
Sep 4, 2003 12:24 PM
