02 SiR Koni Yellow Installation
Old May 11, 2005 | 01:50 PM
blownblind's Avatar
Default 02 SiR Koni Yellow Installation
I just picked up a set of Koni Sports (yellow) for my EP3. When we installed the rears, my ride height was raised about 1.5 inches. I was using a Progress Group spring with the stock strut. Have any of you ever heard of struts affecting the ride height? Also in regards to the fronts, has anyone ever installed a set of yellows with all the cutting, drilling, sleeving and such? Any help would be much appreciated. Thanx
Old May 11, 2005 | 02:56 PM
eMpAtHy's Avatar
Default Re: 02 SiR Koni Yellow Installation (blownblind)
put the spring on a different perch. that will help lower/raise the car to the height you want. 1.5 inches is a lot tho..if you search, you will find a guide to install koni yellows. i believe its in the suspension forum.
Old May 11, 2005 | 03:04 PM
blownblind's Avatar
Default Re: 02 SiR Koni Yellow Installation (eMpAtHy)
There is only one perch for the spring to sit on. They're not upside down or anything either, I made sure they were put in back the same way they came off the stock struts.
Old May 11, 2005 | 05:28 PM
kung fu grip's Avatar
on the konis, the rear perch is reversable. flip it over.
Old May 11, 2005 | 11:42 PM
blownblind's Avatar
Default Re: (kung fu grip)
Thanx
Old May 12, 2005 | 04:49 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kung fu grip &raquo;</TD></TR><TR><TD CLASS="quote">on the konis, the rear perch is reversable. flip it over.</TD></TR></TABLE>
That was suspiciously easy. LOL....
Old May 12, 2005 | 05:06 AM
that question gets asked alot by miata owners. they wind up with a crazy rake. dropped 1.5" in the front, raised 1.5 in the rear. looks fabulous.
Old May 12, 2005 | 09:26 AM
blownblind's Avatar
Default Re: (George Knighton)
I'm not sure if it fixed it yet, i have to take the front struts out first and get those all cut and such, but it sounds like that's probably what happened.
Old May 12, 2005 | 02:17 PM
blownblind's Avatar
Now i'm confused because i went and flipped the driver's side down and once i got over to the passenger side it was already facing down.... which way should they be? Cup facing up or down ??
Old May 12, 2005 | 03:25 PM
if the cup faces down, it's lower.
Old May 12, 2005 | 03:29 PM
this a good article for you
http://www.k-series.com/tech_d..._KONI
Old May 13, 2005 | 12:29 PM
Boilermaker1's Avatar
Cup down, don't be surprised to gain ride height, but it will settle down over a week or so. I did a friend's car and the springs and shocks settled about 3/4" in the first week after the install.
Old May 13, 2005 | 04:58 PM
blownblind's Avatar
Default Re: (Boilermaker1)
Ya cup down, everything is great now, i found that article right after i posted, thanx a lot guys.
DcLs
Sep 18, 2008 06:47 PM
jli18
Suspension & Brakes
51
Nov 30, 2005 06:04 AM
mingbling96
May 1, 2005 07:43 PM
StolenTeg
Jul 19, 2004 03:09 PM
deviant1
May 20, 2004 07:35 PM
