are koni reds height adjustable?
Old May 1, 2005 | 05:30 PM
mingbling96's Avatar
Default are koni reds height adjustable?
are they? i thought i red them somewhere that they were, but then somebody says its not. I know u can adjust the stiffness, but what about height adjustable like the koni yellows? thanks
Old May 1, 2005 | 06:04 PM
maxogsr's Avatar
Default Re: are koni reds height adjustable? (mingbling96)
If it's a coilover yes, if you're talking about the shock itself NO... No shock are ajutable in height... Only in stiffness... They 2 ways to go... Shock + spring or coilover.... Only the second one allow you to ajust the height but it's way lot less confortable for daily use and you need to do alignement everytime you ajust them...
Shock and spring give you a better ride, improves handling depending on spring rates and the quality of shocks... But you sacrifice a bit of handling compare with coilover...
But if it's not for racing purpose, don't go with coilover... Most daily riders regret it after...
Old May 1, 2005 | 06:47 PM
chunk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote"> are koni reds height adjustable?</TD></TR></TABLE>
Nope - "Koni Reds non adjustable strut and Shock sets"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">I know u can adjust the stiffness...</TD></TR></TABLE>
Nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxogsr &raquo;</TD></TR><TR><TD CLASS="quote">No shock are ajutable in height... Only in stiffness</TD></TR></TABLE>
False - See KONI Yellows
Old May 1, 2005 | 06:52 PM
Default Re: are koni reds height adjustable? (maxogsr)
i dunno about you.. but my koni yellows are height adjustable.
Old May 1, 2005 | 07:07 PM
chunk's Avatar
Er... maybe I misunderstood your first post.
KONI Yellows - height and stiff adjustable
KONI Reds - no adjustment
Old May 1, 2005 | 07:43 PM
purplegsr's Avatar
Default Re: are koni reds height adjustable? (chunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunk &raquo;</TD></TR><TR><TD CLASS="quote">Er... maybe I misunderstood your first post.
For the most part, this is correct, unless you are talking about the Koni Red RSK kit. It is valved like the Koni yellows, has an adjustable height perch like Koni yellows. The only drawback is that it uses the old Koni Red 'take shock off car and twist' damping adjustability method.
m!ke
Suspension & Brakes
Jun 24, 2011 04:45 PM
DcLs
Sep 18, 2008 06:47 PM
bbhockey19
Dec 28, 2006 07:54 PM
ieatrice
Dec 27, 2006 07:02 AM
Junkyard2000
Suspension & Brakes
May 28, 2005 10:32 AM
