What test pipe length (i searched)??
Old May 11, 2005 | 11:54 AM
95dc2's Avatar
Default What test pipe length (i searched)??
dc2 chasis, jdm oem 4-1 header, kteller 2.5 catback. how long should i order my test pipe? trying to avoid down time. shop time is tough to come by
TIA for the help
Old May 11, 2005 | 12:04 PM
dFreezy's Avatar
Default Re: What test pipe length (i searched)?? (95dc2)
~17"
Old May 11, 2005 | 12:16 PM
ebelp's Avatar
Depends on how long your b-pipe is. If it's JDM-length, then you'll need a ~12" testpipe, if it's USDM-length, then it'll need to be ~17".
Old May 12, 2005 | 04:49 AM
95dc2's Avatar
anyone else? no one with kteller catback?
Old May 12, 2005 | 06:08 AM
B18C R Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Depends on how long your b-pipe is. If it's JDM-length, then you'll need a ~12" testpipe, if it's USDM-length, then it'll need to be ~17".</TD></TR></TABLE>
Old May 12, 2005 | 09:43 AM
Ryan_C's Avatar
Well, just FYI, I have a Toda 4-2-1 header, T1R catback system w/ a carsound 17" cat.
I could make everything fit a little better if the cat was just a tad shorter. I don't know why that is, but it would prevent the rear section from rattling at idle against the lower suspension parts.
So in my situation, I need a 15" or a 16" cat for sort of the same setup.
Old May 12, 2005 | 09:48 AM
cmdr430's Avatar
pick up one of these.....
http://www.omnipowerusa.com/Pr...e.asp
Old May 12, 2005 | 09:55 AM
tuan...'s Avatar
17''
Old May 12, 2005 | 10:09 AM
ebelp's Avatar
Default Re: What test pipe length (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">pick up one of these.....
http://www.omnipowerusa.com/Pr...e.asp</TD></TR></TABLE>
That's what I'm running now. It's a very good choice because it can be 12" or 17" simply by removing the middle segment.
Old May 12, 2005 | 10:13 AM
cmdr430's Avatar
Default Re: What test pipe length (ebelp)
That's what I'm running now. It's a very good choice because it can be 12" or 17" simply by removing the middle segment. </TD></TR></TABLE>
i knew someone on here had one.... i searched a little but did not see the thread...
90RioEF
Feb 6, 2014 06:58 PM
-faded-
Jul 27, 2007 05:57 AM
Azcheron
Jun 17, 2005 06:38 AM
hYpE-R-29
Aug 20, 2003 03:53 PM
Fuster_Cluck
Oct 27, 2002 07:24 PM
