Engine losing performance or Timing issue
Thanks for reading this topic.
I've tried posting in the Intergra thread, but no replies. I figureI'd try here too.
I have a b18b motor and all of the sudden I'm starting to feel like it's going to die. Let me be more specific. I have 2 problems:
First Problem: The car starts up fine, but when I shift it into 1st gear and steadily accelerate to about 3000rpm the motor feels like it's not going anywhere. It feels kind of like when you red line and can't go any further. This is also consistent through all the gears. I hate this and wonder if anyone has an idea of what it can be. My guess is the timing might need to be adjusted. I just got the car back from my buddy's shop. Plus, I just got a valve adjustment,new valve seals, water pump replaced, new head gasket, new timing belt, new plugs and the pulley replaced. I also got a leak down and a compression test done on all cylinders. When I got it back the timing was off, and we fixed it. The only other thing I can think of is the RAIN. I have a AEM CAI and drive in the rain to work all the time. I know I shouldn't , but that is the only way I can get around. If this is not enough info please let me know.
Second Problem: Even though I have taken the car in for a leak down and compression test, meaning no bad rings or leaks in engine, my car still has black smoke coming out of exhuast and my spark plugs come out covered in oil. What the hell is wrong with this engine???
If anyone can help me please help!!! If you think it's time for a new motor then so be it. If I can rebuild this motor please let me know. Friends have been telling me to buy a new motor but I don't want to spend that much money until I know for sure that my motor is toast.
Thanks-sorry for the novel.
Sounds like the bogging I had in my old D16Z6 due to worn plugs, rotor and cap.
Press on the gas and car still feels like you are letting off of it?
The smoke and fouled plugs also sound like you are running too rich, maybe an oxygen sensor?
Jabuuty671
22
Feb 11, 2012 03:39 PM
trouser chili
Jan 7, 2006 10:53 AM
