Clicking noise in 1st/2nd/reverse when releasing clutch in my 92 accord ex... bad motor mount??
Old May 11, 2005 | 06:33 AM
MakoE2's Avatar
Default Clicking noise in 1st/2nd/reverse when releasing clutch in my 92 accord ex... bad motor mount??
Hey guys after I put the car into gear and then pull off on the clutch to release when i begin to move it makes a slight click/knock noise coming from the transmission area...
someone told me this is probably my mount because it only happens in low gears like 1st/2nd and reverse
the car also shakes back and forth (jerky) when Im shifting in those gears as well... which makes me think it is a mount.
Anyone have this problem or know what it could be?
Thanx guys..
once again its a 92 ex accord sedan 5spd
thank you!!
Old May 11, 2005 | 11:04 AM
MakoE2's Avatar
Default Re: Clicking noise in 1st/2nd/reverse when releasing clutch in my 92 accord ex... bad motor mount??
nobody knows? someone in here must have seen this before..
Old May 11, 2005 | 11:48 AM
JimBlake's Avatar
We can't see it from here, but I can suggest you look for yourself.
Open the hood & watch. Hold the brakes, while you begin engaging the clutch. (You'll have to use a heel/toe technique.) Does the engine rock too much & make the noise?
Alternatively, you can grab the valve cover & try to shake the engine.
Mohammed_q
Dec 28, 2007 08:04 PM
redrelease
10
Aug 15, 2006 05:40 PM
silversurfer2282
Sep 21, 2003 11:59 AM
RCLGSR
Jan 29, 2002 10:12 PM
stRtypR25
Jan 20, 2002 06:30 PM
