What ecu's and wireing harness will work with this motor?
I have a 98 d16 sohc non v-tec and I was wondering what ecu and wireing harness will work with it. I was wondering if the ecu and wiring from 90 up will work and what it would take, If someone could tell me, I would really apperiate it. Thank you.
Wiring for a 96-98 Civic will work. Any other harness will need work. You need to run a P2E ECU.
If you have an pre 96 Civic harness, you are missing sensors and the plugs will be different. The ECU you need is from a 96-98 Civic DX, CX, or LX.
I have a 96 civic ex with a d16y7 and a p2p on my car.When I connect a p2e ecu on my car, doesn't seem to want to turn on my car but the p2p does turn it on. Good luck with your car
