hondata with vafc
Old May 10, 2005 | 10:36 PM
b20izzle's Avatar
Default hondata with vafc
first off this is a NoOb *** question so dont shoot me. I have a s200 but i dont have a laptop..i want to monitor my rpms and was thinkin of pluggin my vafc back into it. would i run into any problems?
Old May 11, 2005 | 01:37 PM
CRXDrew's Avatar
shouldn't be a problem if the VAFC is set to stock settings.
Old May 11, 2005 | 01:40 PM
mrbsponge's Avatar
you can do this, just dont hook up the MAP sensor, this is how the vafc adjusts for fuel,
you can watch rpms, and whatnot, just dont let it be used as an actual controller
Old May 11, 2005 | 01:52 PM
CRXDrew's Avatar
^ yea thats what i meant. If you jsut need it for RPM's then hook up just the RPM leads... otherwise just don't hook up the other things that do more than just piggy back a signal.
Old May 11, 2005 | 08:01 PM
b20izzle's Avatar
Default Re: (CRXDrew)
thanks guys..so i just dont hook up the map? would it be easier to just get my stock tach adjusted?
EG6R's Avatar
Default Re: hondata with vafc (b20izzle)
Ive a hondata stage 3 and a vafc. Only the display is working. I left the A/F and Vtec controller disconnected.
Old May 12, 2005 | 12:19 AM
mtber's Avatar
Default Re: hondata with vafc (EG6R)
Read this http://www.phearable.net/tech/....html
Old May 12, 2005 | 05:25 AM
Jason.H.'s Avatar
Default Re: hondata with vafc (mtber)
yea just hook up the power the ground the rpm signal and the tps signal
twiztid00002
Jan 14, 2008 09:31 PM
tub_sephiroth
Dec 5, 2004 07:53 PM
sh-ef
Jun 28, 2004 07:15 AM
juniordc2
Jun 8, 2003 11:15 PM
RedTeg95
Mar 29, 2002 09:33 AM
