AEM fuel rail or Golden Eagle Fuel rail?
Old May 10, 2005 | 10:29 PM
Mr si99's Avatar
Default AEM fuel rail or Golden Eagle Fuel rail?
Is there anything significant difference b/w these two? and which one do you prefer? my si fuel rail leak gas like dripping water so just wondering what do u guys think? they're only 10 to 15 dollar difference (10-15 dolla of lunch money ).
Old May 10, 2005 | 10:33 PM
Slipjack's Avatar
Default Re: AEM fuel rail or Golden Eagle Fuel rail? (Mr si99)
Golden eagle has a fuel bore of 11/16”
AEM has a fuel bore of 1/2"
If that helps any.
EDIT: I know for a fact the AEM fuel rail works with stock injectors and fuel hose. Not sure about Golden Eagle, but probably.
Old May 11, 2005 | 03:42 AM
sinister6's Avatar
I dont know, i have been told stock will work real fine unless your high-boosted?
Old May 11, 2005 | 05:03 AM
JamesV's Avatar
aem. because there they rock.
i need to change my stocky fuel rail.. getting kinda dirty going for the aem. i suggest you go for it too!
Old May 11, 2005 | 06:11 AM
JDMlyfestyle's Avatar
GE accepts OEM injectors as well.
Old May 11, 2005 | 07:18 AM
IHateJDM's Avatar
Default Re: (sinister6)
stock fuel rail can easily hold 350 hp. just get the one that's cheapest and works with the least amount of work. they will all perform the same unless you have a big turbo on a built motor.
Old May 11, 2005 | 08:04 AM
turboman's Avatar
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">stock fuel rail can easily hold 350 hp. just get the one that's cheapest and works with the least amount of work. they will all perform the same unless you have a big turbo on a built motor.</TD></TR></TABLE>
Yeah I'm wondering why everyone changes this. But to each there own. I know I have bought lots of useless stuff.
Old May 11, 2005 | 08:16 AM
Soccerking3000's Avatar
Default Re: (turboman)
its bling lol, i have an str fuel rail and no complaints, but i had to get new fuel lines for it, but i dont have a problem upgrading things to stainless steel flex lines so whateva
Old May 11, 2005 | 08:51 AM
EeeJayEight's Avatar
Default Re: (Soccerking3000)
i used an AEM rail before... but i felt no difference at all since i wasnt boosted.... anyways i sold it and put a stock one on... maybe u should just look into stock unless u knew some high fuel flow for boost
Old May 11, 2005 | 08:54 AM
_gurusan_'s Avatar
Default Re: (EeeJayEight)
I use a cheapy one...forgot the brand name but it works well....
Just use a stock one or get some POS off ebay
Old May 11, 2005 | 09:01 AM
Grand's Avatar
ya there just ofr looks unless your motor is crazy built or boosted
but they do look good lol
Old May 11, 2005 | 09:46 AM
Slipjack's Avatar
Default Re: (LG_R32)
If you want to start building your engine for looks, colored spark plug wires, with matching strut tower bar, fuel rail, and valve cover are good places to start. All but the valve cover even do something for reliability/performance. Whenever my cousin gets a used car first thing he does to the motor (after checking for leaks) is take a big bucket of degreaser to it. Looks pretty clean!
Old May 11, 2005 | 11:23 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: AEM fuel rail or Golden Eagle Fuel rail? (Slipjack)
i like my vortech rail because of the o-ring fittings. and they work with rc's and stockers. not to hijack, but personally i dont like the aem rail.
Old May 11, 2005 | 08:15 PM
Mr si99's Avatar
yea even if it doesn't make any difference i just want to upgrade it to a better fuel rail so the same problem don't happen. The fuel was dripping like a leaking water cup. it's not drip stop drip , its constantly flowing and i've been driving like that for the past 2 month. Though i dont know if the problem started 2 month ago maybe even longer. So I just want a reliable one that will be able to handle built motor (for the future) and wont cause a the same problem again for a stock car like mines. 1 more thing what do u guys think about golden eagle fuel rail. and what do they come with. Does it come with everything like the AEM fuel rail?
Old May 11, 2005 | 09:48 PM
Seedc2's Avatar
i like the fact that you can mount the fuel pressure gauge on the aftermarket fuel rail
Old May 16, 2005 | 06:13 PM
KtHaNxBai's Avatar
egay
find a aem
u can find them for cheap,
i found mine brand new for 25shipped
tooquik209
Sep 11, 2012 12:40 AM
Boosteddb8
Sep 22, 2007 07:35 AM
redboost10
Feb 19, 2006 05:50 PM
bluebullet
Jan 7, 2004 08:44 AM
