need help (fuel pump)
Old May 10, 2005 | 08:39 PM
sa90eg's Avatar
Default need help (fuel pump) and 95 gsr tranny f/s cheap
after installing walbro 255 fuel pump, losing fuel pressure when reving the motor, boggs out then motor dies... plus alternater fuse keeps burnning out since fuel pump was installed. this is on an ef civic
GSR tranny no grinds (SOLD)
Modified by sa90eg at 12:33 PM 5/11/2005
Modified by sa90eg at 12:34 PM 5/11/2005
Modified by sa90eg at 12:36 PM 5/11/2005
Old May 11, 2005 | 11:36 AM
sa90eg's Avatar
Default Re: need help (fuel pump) and 95 gsr tranny f/s cheap (sa90eg)
ttt
Old May 11, 2005 | 11:39 AM
NikoZai's Avatar
Default Re: need help (sa90eg)
bet your alternator is dying, and i bet thats why its bogging, loss of spark
Does the alternator belt squeel ever? and have you had to charge your battery?
Otherwise, Check your fuel pressure to confirm if it actually has something to do with the pump or not.
Old May 11, 2005 | 11:52 AM
sa90eg's Avatar
Default Re: need help (NikoZai)
battery light does come on befor and still does,but everything was fine when i had my stock dx pump,i had a feeling alternater was weak but never had to jump start just that sometime car would die out if you don't give it gas while coming to a stop. plus walbro fuel pump is brand new... thanks
Old May 11, 2005 | 05:29 PM
sa90eg's Avatar
ttt
Old May 11, 2005 | 09:12 PM
sa90eg's Avatar
bump
Old May 11, 2005 | 09:19 PM
PURPLETERROR aka BIGMATT's Avatar
Sounds like you have a charging system problem.
Old May 12, 2005 | 12:38 AM
sa90eg's Avatar
ttt
Old May 12, 2005 | 10:37 AM
sa90eg's Avatar
bump
Old May 12, 2005 | 11:23 AM
2kTeg's Avatar
go threw the motions, undo the neg when it car is on and see if it still runs..... turn all your accessorys on and your stereo up and see if makes your car die faster check all the wiring you did for your walbro u fucked something up if it ran fine b4
Old May 12, 2005 | 04:48 PM
sa90eg's Avatar
what's the chances of a bad fuel filter
Old May 14, 2005 | 04:59 PM
sa90eg's Avatar
ttt
Old May 14, 2005 | 05:43 PM
OptimusPrimeX's Avatar
dude.. its hard to *** up your fuel pump, possible, but most likely not.
Do this
Clean all your grounds from the battery.. either with sand paper, or with an adaptor for a drill.. wire brush.
Make sure all the grounds are TIGHT!!! this is very important.
After that, i would test the battery with a Test light, and see if it's putting out the right power. If you dont have a test light, then see if you can borrow a battery from someone or try another one.. batteries are freaks.. sometimes you'll think its electrical .. and its just your battery.
After all that, then you can pin it to either the alternator, and lastly the fuel pump.
Its amazing what a dying battery or alternatorcan do!.. especially when there is the smallest need for more power drawn.
i think its a power issue.. alternator or Battery.
Old May 15, 2005 | 07:42 PM
sa90eg's Avatar
bump
Old May 17, 2005 | 02:29 PM
sa90eg's Avatar
ttt
pappasmurf
Nov 11, 2024 07:43 AM
dfbdavid38
Jan 21, 2011 05:27 AM
Gman8941
Jul 18, 2004 07:37 PM
